Vpn configuration question
Hey guys its been a long time since i really configured a mikrotik. so im having a bit of an issue configuring the vpn, im trying to figure out if its configuration issue with the actual adsl modem or if i have a error in the vpn configuration.
I’ll explain the setup, have 3 locations that report back to one microtik, thats already configured for a pptp client(adsl) to another rb750 that has the server binding on it which it is on a fibre connection.So I have 2 other locations that need to be setup the same as the fibre connection but they are on adsl connections. i configured dyndns on the new test router but cant get the vpn to connect. mimiked the settings from the working fibre configuration but changing IP addresses. But I think my issues is im having issues with ports on the adsl modem. do i not have to forward ports from the modem to the router? from what i read port 47 and port 1723 is that not correct. Its been far too long that ive played with the configurations i dont remember what i need to do.
