VPN connection error
Hi!
First, I created PPPoE connection, then after disconnection I tried out the PPtP connection - but it fails. The login procedure (on the client XP) hangs up at “verifying username/password”, then after a couple of seconds, an error message is displayed code 619.
I can’t imagine what could cause this error, I think configuring a VPN is a quite straight-forward procedure…
I found another topic with the same error but it’s in the archive. And it didn’t worked for me (delete/recreate everything).
