VPN Connection Issue on Specific Devices: Error Code 800 and SSTP Request Failure
Hello everyone,
I've encountered a perplexing issue with my VPN setup on a MikroTik RB2011iLS router. While I'm able to establish a VPN connection on some devices, two specific devices are unable to connect and are throwing an error code 800 related to SSTP.
Network Configuration:
MikroTik RB2011iLS running RouterOS (latest version)
VPN set up for SSTP
Local devices range from 192.168.88.10 to 192.168.88.50
MikroTik Router IP: 192.168.88.1
Error Message:
CoID={ANONYMIZED_ID}: The user "ANONYMIZED_USER" has chosen a connection named "ANONYMIZED_CONNECTION", but the connection could not be established. The reason code returned by the error is: 800.
CoId={ANONYMIZED_ID}: The initial SSTP request could not be successfully sent to the server. This may be due to network connection issues or certificate problems (trust relationship). Below is the detailed error message. Resolve the issue and try again.
A connection attempt has failed because the connected party did not respond correctly after a certain period of time, or the established connection was faulty because the connected host did not respond.
Thank you for your assistance.
Best regards.
CONF
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=default-dhcp ranges=192.168.88.201-192.168.88.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.88.1 remote-address=default-dhcp
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface ovpn-server server
set auth=sha1,md5
    192.168.88.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.88.0/24
/ppp secret
add name=vpn
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=RouterOS
/system logging
add topics=ppp
add topics=firewall
add topics=ssh
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
