VPN Connection Issue with different ISPs
I am using the MikroTik RB 450G and I have an issue when connecting to the VPN. I have two ISP connections and one ISP connection is working well with the VPN and always get connected. But when I am using the other ISP it says cant connect to the VPN and gives below error with the same settings. Is this a ISP issue or is there any way to correct this using router settings?
“A connection between your computer and the VPN server has been established but the VPN connection cannot be completed. The most common cause for this failure is that at least one Internet device (for example, a firewall or router) between your computer and the VPN server is not configured to allow Generic Routing Encapsulation (GRE) protocol packets. If the problem persists, contact your network administrator or Internet Service Provider.”
I am Using the Windows default VPN client
