VPN Connection to wAP LoRa8
Hello !
Please tell me how can I connect to remote wAP LoRa8 gateways through VPN.
I have seen on my wAP LoRa8 some settings about VPN connection but I couldn’t make it work…
I enabled VPN Access box, I have a VPN Address, I have a user name, and a VPN password.
I tried to make a new connection with that settings but didn’t worked for me and I don’t know what else to do…
Can you help me, please to remote connect to any of my Mikrotik Lora8 Gateways through VPN ?
I am using Windows 7 x64.
Thank you very much !
What VPN tunnel did you try to setup ? What went wrong ?
In Windows 7 I tried to make a standard new VPN Connection using the link below :
https://www.groovypost.com/howto/howto/setup-the-windows-7-vpn-client/
For that new VPN connection I used the Mikrotik Lora8 provided credentials like VPN address and user name and a custom defined password.
Every time when I tried to connect, I got the error 691 : The remote connection was denied because the user name and password combination you provided is not recognized…
I also tried without my defined password… with the same result.
Thank You !
You still dont answer what type of VPN tunnel you configured (and how) on your Mikrotik…
Sorry but on my Mikrotik Lora8 device I did not made any settings for VPN,except the password located under VPN Address,VPN Username…
Can you, please tell me what settings should I do ?
Thank You !
You can have a look at the examples here https://wiki.mikrotik.com/wiki/Manual:Interface/L2TP#Basic_L2TP.2FIpSec_setup
