VPN disconnects
I have hAP ac2 model with Router OS 6.46.1 configured as router over PPPoE connection and everything works perfectly.
Now I want to add another VPN connection - PPTP - to forward certain traffic over this VPN connection.
Problem: PPTP connection establishes but after several seconds disconnects.
Debug logs:
07:07:03 pptp,ppp,info vpn: authenticated
07:07:03 pptp,ppp,debug vpn: IPCP lowerup
07:07:03 pptp,ppp,debug vpn: IPCP open
07:07:03 pptp,ppp,debug,packet  vpn: sent IPCP ConfReq id=0x13
07:07:03 pptp,ppp,debug,packet     <addr 0.0.0.0>
07:07:03 pptp,ppp,debug vpn: IPV6CP open
07:07:03 pptp,ppp,debug vpn: MPLSCP lowerup
07:07:03 pptp,ppp,debug vpn: MPLSCP open
07:07:03 pptp,ppp,debug,packet  vpn: sent MPLSCP ConfReq id=0xa
07:07:03 pptp,ppp,debug vpn: BCP open
07:07:03 pptp,ppp,debug vpn: CCP lowerup
07:07:03 pptp,ppp,debug vpn: CCP open
07:07:03 pptp,ppp,debug,packet  vpn: sent CCP ConfReq id=0xa
07:07:03 pptp,ppp,debug,packet     <mppe 1000040>
07:07:03 pptp,ppp,debug,packet  vpn: rcvd CCP ConfReq id=0x1
07:07:03 pptp,ppp,debug,packet  vpn: sent CCP ConfAck id=0x1
07:07:03 pptp,ppp,debug,packet  vpn: rcvd IPCP ConfReq id=0x1
07:07:03 pptp,ppp,debug,packet     <addr 10.121.192.1>
07:07:03 pptp,ppp,debug,packet  vpn: sent IPCP ConfAck id=0x1
07:07:03 pptp,ppp,debug,packet  vpn: rcvd LCP ProtRej id=0x3
07:07:03 pptp,ppp,debug,packet      82 81
07:07:03 pptp,ppp,debug,packet  vpn: rcvd IPCP ConfNak id=0x13
07:07:03 pptp,ppp,debug,packet     <addr 10.121.246.67>
07:07:03 pptp,ppp,debug,packet  vpn: sent IPCP ConfReq id=0x14
07:07:03 pptp,ppp,debug,packet  vpn: rcvd CCP ConfAck id=0xa
07:07:03 pptp,ppp,debug vpn: CCP opened
07:07:03 pptp,ppp,info vpn: using encoding - MPPE128 stateless
07:07:03 pptp,ppp,debug,packet  vpn: rcvd IPCP ConfAck id=0x14
07:07:03 pptp,ppp,debug vpn: IPCP opened
07:07:03 pptp,ppp,info vpn: connected
07:07:07 pptp,ppp,debug,packet  vpn: rcvd LCP TermReq id=0x4
07:07:07 pptp,ppp,debug vpn: LCP closed
07:07:07 pptp,ppp,debug vpn: CCP lowerdown
07:07:07 pptp,ppp,debug vpn: CCP closed
07:07:07 pptp,ppp,debug vpn: BCP lowerdown
07:07:07 pptp,ppp,debug vpn: BCP down event in starting state
07:07:07 pptp,ppp,debug vpn: IPCP lowerdown
07:07:07 pptp,ppp,debug vpn: IPCP closed
07:07:07 pptp,ppp,debug vpn: IPV6CP lowerdown
07:07:07 pptp,ppp,debug vpn: IPV6CP down event in starting state
07:07:07 pptp,ppp,debug vpn: MPLSCP lowerdown
07:07:07 pptp,ppp,debug,packet  vpn: sent LCP TermAck id=0x4
07:07:07 pptp,ppp,debug vpn: LCP lowerdown
07:07:07 pptp,ppp,debug vpn: BCP close
07:07:07 pptp,ppp,debug vpn: IPV6CP close
07:07:07 pptp,ppp,debug vpn: MPLSCP close
07:07:07 pptp,ppp,info vpn: terminating...
My guess is that problem is related to “vpn: rcvd LCP ProtRej id=0x3”. I found following link http://pptpclient.sourceforge.net/howto-diagnosis.phtml#lcp_protrej_2 which assumes problem with VPN server configuration which is unlikely as the same PPTP connection works on another Mikrotik device (v 6.45.6) in different location. Also I tried L2TP (with IPSec tunnel - according to instruction from VPN provider) and had same symptoms.
Device has following firewall rules (basically default configuration):
0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; Add Syn Flood IP to the list
      chain=input action=add-src-to-address-list tcp-flags=syn connection-limit=30,32 protocol=tcp address-list=Syn_Flooder address-list-timeout=30m
 2    ;;; Drop to syn flood list
      chain=input action=drop src-address-list=Syn_Flooder
 3    ;;; Port Scanner Detect
      chain=input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1 address-list=Port_Scanner address-list-timeout=1w
 4    ;;; Drop to port scan list
      chain=input action=drop src-address-list=Port_Scanner
 5    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 6    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 7    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 8    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
 9    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
10    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
11    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related
12    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
13    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
14    ;;; defconf:  drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
Does anyone have any clue what can be wrong?
For PPTP (server) you need to accept the port tcp 1723 and Gre (47) protocol in the input chain…
Thanks for reply, but issue still there - after 4 seconds connection terminates, same “rcvd LCP ProtRej id=0x3” in the log.
Changed rules like this:
< same as above >
 8    chain=input action=accept protocol=tcp port=1723
 9    chain=input action=accept protocol=gre
10    ;;; defconf: drop all not coming from LAN
 < same as above >
Saw zero counters in stats for 8 and 9 afterward.
Just to clarify: I have active and masqueraded PPPoE connection while trying to connect PPTP, no any nat/mangle rules for PPTP yet, just checking PPTP.
Just created trial account on SaferVPN.com and added PPTP connection with same parameters as before (only with different user/pass/connect-to) - connection is up and running.
Looks like original problem is related to prior VPN provider…
