when eth3 fails, internet traffic still works ok with different WAN ip ok eth2.
VPN for a specific service lost connection and I am not able to use it anymore until I manually restart the full router disconnecting everyone including VoIP traffic or when the eth3 comes online again.
So the problem is with the VPN. Is there a way that I can make the VPN work again without having to restart the full router or without human intervention, kind of a automatic task and also when the link comes back again the VPN reconnects with the primary wan?
I got the latest firmware version update and this was a configuration that was done by other person and it was supposed to be working like that, but we have changed One of the ISP’s keeping the old main as the backup link si what i have made is only change ip addresses and distances on each route.
Any information will be very well appreciated, thanks in advance.
Or, simpler, just use /ip firewall connection remove [find dst-address~“:(5|17|45)00$” protocol=udp] in the script (if we really talk about L2TP over IPsec here, otherwise different protocols and ports have to be specified), so that you wouldn’t need to connecion-mark the VPN transport connection specifically.
However, if the VPN client is the Mikrotik itself and not a device on its LAN, it should be enough to prevent the src-nat or masquerade rule on WAN from being used on locally originated packets, so that the VPN connection would not get src-nated. In that case you shouldn’t need to remove connections using a script as the reason why they need to be removed is that once a NAT address is assigned to a connection, it never changes unless it was assigned by a masquerade rule and the interface goes down or gets a new address - in these cases, RouterOS removes masqueraded connections automatically. So if there is an issue further in the network and the WAN doesn’t actually go down or change address, the auto-cleanup associated to masquerade is not executed.
