vpn help
Have a vpn running with a cisco pix. The tunnel is up and connected by cannot pass traffic. Not sure what to do on the mikrotik side. The cisco side is pretty cut and dry. I know that is right. I’ve seen a lot of things about adding firewall rules to the routeros and other things so not sure what I am missing. At this point I see no traffic reaching the cisco firewall it’s all zeros on the show cry ips sa counts.
What is your configuration for IPSec?
What do you have in /ip ipsec installed-sa print?
The “I know that is right” is NOT accurate. It IS, perhaps, configured the way you want the tunnel to run. To make it “right”, however, you would have to be able to pass traffic. With that said, you will need to verify that the tunnel is established. In MT, that is done with “/ip ipsec installed-sa print”. You should have 2 entries. You’ll need to provide that information first. In order to get the circuit working, you will need to provide more detail, as there are no known mind readers perusing MT’s forums.
