VPN IPSec Lan to Lan problems
First of all thanks for helping.
I have a messed up problem and i don’t know how to fix it.
We have 1 mikrotik with an ipsec connection to an pfsense, its working 100% correctly.
All packages are received and sent from and to both ends.
The situation below goes for the other 3 mikrotiks in our network.
We have the same mikrotik with an IPSec connection to an other mikrotik, the phase1 and phase2 are established and ping trough the tunnel is working, however:
  • http to the mikrotik gives an timeout i can’t establish that connection, ssh works
  • http to other devices in other netwerk connections establish in telnet but i get 408, ssh works
  • voip connections work through the tunnel
Hope you guys can help me! Thanks!
