VPN/ipsec with strongSwan
I tried to establish a VPN/Ipsec between my Mikrotik router and my Android tablet.
Side Android, I installed strongSwan.
Side Mikrotik:
/ip ipsec mode-config
add address-pool=ike2-pool address-prefix-length=32 name=ike2-conf \
    split-include=0.0.0.0/0
/ip ipsec policy group
add name=ike2-policies
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-128,3des
add dh-group=ecp256,modp3072,modp2048,modp1024 enc-algorithm=\
    aes-256,aes-192,aes-128,3des name=ike2-profile
/ip ipsec peer
add exchange-mode=ike2 name=ike2-peer passive=yes profile=ike2-profile
/ip ipsec proposal
add auth-algorithms=sha256,sha1 enc-algorithms=\
    aes-256-cbc,aes-192-cbc,aes-128-cbc,3des name=ike2-proposal pfs-group=\
    none
/ip ipsec identity
add auth-method=rsa-signature certificate=server-tabl generate-policy=\
    port-strict mode-config=ike2-conf peer=ike2-peer policy-template-group=\
    ike2-policies
/ip ipsec policy
add dst-address=192.168.77.0/24 group=ike2-policies proposal=ike2-proposal \
    src-address=0.0.0.0/0 template=yes
The three certificates:
name="ca" digest-algorithm=sha256 country="" state=""
locality="" organization="" common-name="ca"
key-size=4096 subject-alt-name="" days-valid=3650 trusted=yes
key-usage=key-cert-sign,crl-sign
ca-crl-host="<my hostname>"
name="client-tablette" digest-algorithm=sha256 country=""
state="" locality="" organization=""
common-name="client-tablette" key-size=4096 subject-alt-name=""
days-valid=3650 trusted=no key-usage=digital-signature,tls-client
ca=ca
name="server-tabl" digest-algorithm=sha256 country=""
common-name="<my hostname>" key-size=4096
subject-alt-name=DNS:::<my hostname>
key-usage=digital-signature,tls-server ca=ca
The log display:
got critical ERROR: authentication failed
The strongSwan log display:
received end entity: …
using certificate …
using trusted ca …
checking certificate status of …
certificate status is not available
authentication of … with RSA successful
constraint check failed: identity: required
I don’t see the error(s) … and you ?
Thanks by advance
Just before the error, the log display this:
Did you resolve the problem? Now I’m facing on this one. THX in advance.
+1 Android strongswan client. WTF How to get rid of it.
Strongswan requires the IP address or fqdn of the responder (the Mikrotik) to be in the Subject Alt Name field of its certificate.
So to clarify things up for everyone - Strongswan app on Android has no option to force ignore this constraint. In order to fix it, you must generate a new certificate for your VPN server, but this time with correct subject-alt-name. E.g. I am always using “/ip cloud” DNS to connect to a VPN server, so I used this DNS record in VPN Server’s certificate, subject-alt-name field. Format “DNS:”.
This is how I generated all the certificates for “IPSEC/IKE2 with certificates” profile in Android strongswan, and everything worked:
# Generate CA
/certificate add name="My CA" common-name="My CA" key-size=4096 days-valid=3650 key-usage=key-cert-sign,crl-sign
# Generate client and server certs
/certificate add name="My client" common-name="My client" key-size=4096 days-valid=3650 key-usage=digital-signature,key-encipherment,tls-client
/certificate add name="My server" subject-alt-name="DNS:XXXXXXXXXXX.sn.mynetname.net" common-name="My server" key-size=4096 days-valid=3650 key-usage=digital-signature,key-encipherment,tls-server
# Sign CA
/certificate sign "My CA"
# Sign certs using signed CA
/certificate sign "My client" ca="My CA"
/certificate sign "My server" ca="My CA"
# Trust certs
/certificate set "My client" trusted=yes
/certificate set "My server" trusted=yes
# Export client certificates in P12 format
/certificate export-certificate "My client" file-name=myclient type=pkcs12 export-passphrase=1234567890
My server is used for VPN Server, and My client is used in Strongswan client on Android.
