VPN Issue (Split Tunneling)
Hello.
I have been having an issue with on-line games when I have VPN enabled.
Currently, I have setup selective routing (only set IP ranges I set go through the VPN while the rest go for the PPPoE interface) for my VPN and for the most part it works (HTTP/ICMP/SSL). However when I attempt to play games which are routed through the VPN, the connection fails.
I am 100% of the IPs that are set as part of the VPNR list. I know the game is attempting to connect via VPN since it fails (other games that connect directly are working properly).
I am assuming UDP tunneling may be an issue. The website for the tunneled game (Blizzard) are opening properly without any issues. Can anyone see my rudimentary configuration and tell me where I am messing up?
Best Regards,
-aL
You can try a mangle to mark the udp traffic going to Blizzard. Then just create a specific route, to the destination and set to route the marked packets thru that.
