I’ve set up PPTP VPN on several MK routers. They all work except for one problem. I need to access the local network hosted by the MK router. Only one of the routers works right. It has to be a firewall issue, as the only major difference is the firewall settings.
On the problem routers I was able to set them up so I could get to the router itself by adding a FW rule to accept input on the local subnet, which seems odd as everything on the local subnet already has access. But it worked.
Below is my fw list. Adding rule 3 allowed me to access the router itself, but nothing else in the network. Also, the VPN assigns to my computer an IP within the local network structure: i.e. 192.168.1.x
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
2 ;;; PPTP VPN
chain=input action=accept protocol=tcp dst-port=1723 log=no log-prefix=“”
3 chain=input action=accept src-address=192.168.1.0/24 log=no log-prefix=“”
4 ;;; Guest isolation
chain=forward action=drop src-address=10.0.1.0/24 dst-address=192.168.1.0/24 log=no log-prefix=“”
5 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
6 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
7 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
8 ;;; Block Guest to Lan
chain=forward action=drop in-interface=bridge-vlan10 out-interface=bridge log=no log-prefix=“”
9 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
10 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
11 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related
12 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
13 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
14 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
15 ;;; Accept established connections
chain=input connection-state=established
16 ;;; Accept related connections
chain=input connection-state=related
17 ;;; Drop invalid connections
18 ;;; UDP
chain=input action=accept protocol=udp
19 ;;; drop invalid connections
20 ;;; Allow limited pings
chain=input protocol=icmp limit=50/5s,2
21 ;;; Drop excess pings
chain=input action=drop protocol=icmp
22 ;;; DROP PING REPLY
chain=input action=drop protocol=icmp src-address=!10.10.0.4
23 ;;; Drop Blaster Worm
chain=virus action=drop protocol=tcp dst-port=135-139
24 ;;; Drop Messenger Worm
chain=virus action=drop protocol=udp dst-port=135-139
25 ;;; Drop Blaster Worm
chain=virus action=drop protocol=tcp dst-port=445
26 ;;; Drop Blaster Worm
chain=virus action=drop protocol=udp dst-port=445
27 ;;; ________
chain=virus action=drop protocol=tcp dst-port=593
28 ;;; ________
chain=virus action=drop protocol=tcp dst-port=1024-1030
29 ;;; Drop MyDoom
chain=virus action=drop protocol=tcp dst-port=1080
30 ;;; ________
chain=virus action=drop protocol=tcp dst-port=1214
31 ;;; ndm requester
chain=virus action=drop protocol=tcp dst-port=1363
32 ;;; ndm server
chain=virus action=drop protocol=tcp dst-port=1364
33 ;;; screen cast
chain=virus action=drop protocol=tcp dst-port=1368
34 ;;; hromgrafx
chain=virus action=drop protocol=tcp dst-port=1373
35 ;;; cichlid
chain=virus action=drop protocol=tcp dst-port=1377
36 ;;; Worm
chain=virus action=drop protocol=tcp dst-port=1433-1434
37 ;;; Bagle Virus
chain=virus action=drop protocol=tcp dst-port=2745
38 ;;; Drop Dumaru.Y
chain=virus action=drop protocol=tcp dst-port=2283
39 ;;; Drop Beagle
chain=virus action=drop protocol=tcp dst-port=2535
40 ;;; Drop Beagle.C-K
41 ;;; Drop MyDoom
chain=virus action=drop protocol=tcp dst-port=3127-3128
42 ;;; Drop Backdoor OptixPro
chain=virus action=drop protocol=tcp dst-port=3410
43 ;;; Worm
chain=virus action=drop protocol=tcp dst-port=4444
44 ;;; Worm
chain=virus action=drop protocol=udp dst-port=4444
45 ;;; Drop Sasser
chain=virus action=drop protocol=tcp dst-port=5554
46 ;;; Drop Beagle.B
chain=virus action=drop protocol=tcp dst-port=8866
47 ;;; Drop Dabber.A-B
chain=virus action=drop protocol=tcp dst-port=9898
48 ;;; Drop Dumaru.Y
chain=virus action=drop protocol=tcp dst-port=10000
49 ;;; Drop MyDoom.B
chain=virus action=drop protocol=tcp dst-port=10080
50 ;;; Drop NetBus
chain=virus action=drop protocol=tcp dst-port=12345
51 ;;; Drop Kuang2
chain=virus action=drop protocol=tcp dst-port=17300
52 ;;; Drop SubSeven
chain=virus action=drop protocol=tcp dst-port=27374
53 ;;; Drop PhatBot, Agobot, Gaobot
chain=virus action=drop protocol=tcp dst-port=65506
54 ;;; jump to the virus chain
chain=forward action=jump jump-target=virus
55 ;;; Port scanners to list
chain=input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1 address-list=port scanners address-list-timeout=2w
56 ;;; NMAP FIN Stealth scan
chain=input action=add-src-to-address-list tcp-flags=fin,!syn,!rst,!psh,!ack,!urg protocol=tcp address-list=port scanners address-list-timeout=2w
57 ;;; SYN/FIN scan
chain=input action=add-src-to-address-list tcp-flags=fin,syn protocol=tcp address-list=port scanners address-list-timeout=2w
58 ;;; SYN/RST scan
chain=input action=add-src-to-address-list tcp-flags=syn,rst protocol=tcp address-list=port scanners address-list-timeout=2w
59 ;;; FIN/PSH/URG scan
chain=input action=add-src-to-address-list tcp-flags=fin,psh,urg,!syn,!rst,!ack protocol=tcp address-list=port scanners address-list-timeout=2w
60 ;;; ALL/ALL scan
chain=input action=add-src-to-address-list tcp-flags=fin,syn,rst,psh,ack,urg protocol=tcp address-list=port scanners address-list-timeout=2w
61 ;;; NMAP NULL scan
chain=input action=add-src-to-address-list tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg protocol=tcp address-list=port scanners address-list-timeout=2w
62 ;;; dropping port scanners
chain=input action=drop src-address-list=port scanners
63 ;;; drop ftp brute forcers
chain=input action=drop protocol=tcp src-address-list=ftp_blacklist dst-port=21
64 chain=output action=accept protocol=tcp content=530 Login incorrect dst-limit=1/1m,9,dst-address/1m
65 chain=output action=add-dst-to-address-list protocol=tcp address-list=ftp_blacklist address-list-timeout=3h content=530 Login incorrect
66 ;;; drop ssh brute forcers
chain=input action=drop protocol=tcp src-address-list=ssh_blacklist dst-port=22
67 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=ssh_stage3 address-list=ssh_blacklist address-list-timeout=3d
dst-port=22
68 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=ssh_stage2 address-list=ssh_stage3 address-list-timeout=1m
dst-port=22
69 chain=input action=add-src-to-address-list connection-state=new protocol=tcp src-address-list=ssh_stage1 address-list=ssh_stage2 address-list-timeout=1m
dst-port=22
70 chain=input action=add-src-to-address-list connection-state=new protocol=tcp address-list=ssh_stage1 address-list-timeout=1m dst-port=22
71 ;;; drop ssh brute downstream
chain=forward action=drop protocol=tcp src-address-list=ssh_blacklist dst-port=22
