VPN issue
I have a customer running the VPN server in MS Server 2003 - we have natted him to the outside world - all ports are open etc but he says only one client can connect at a time.
Are there known problems with MT 2.8.26 and concurrent VPN connections via NAT? Or is it more likely to be a licensing issue on his box?
Trisc
this is usally a issue with allowing more then 1 vpn . try allowing or adding
ipsec passthru to that address.
one of the MT gurus should know how to do this..
we have had this issue with our main sdsl router . if we dont allow ipsec pass thru it will drop everything after the first connection . or about every 10 min it will kick them out .
if you do 1 to 1 nat that might also fix this issue
Randy
I found the answer by searching the forum - gre and pptp ports need to be enabled to allow concurrent sessions through.
Trisc
