VPN ISsue
Can anyone guide me for Configuring Mikrotik as VPN Server for Windows based Clients.
Any specific documents, Help Documents are welcome
Its bit urgent.
Regards,
Sishith Asok R
Setup on PPTP server:
  1. Add a user:
[admin@PPTP-Server] ppp secret> add name=jack password=pass \
            \... local-address=10.0.0.1 remote-address=10.0.0.2
  1. Enable the PPTP server:
[admin@PPTP-Server] interface pptp-server server> set enabled=yes
taken from:
http://www.mikrotik.com/docs/ros/2.9/interface/pptp
Is it possible to control the User Access when a user connected to Via VPN. I mean i need to deny some subnet access and provide some particular ip address access.
Sishith
please, do yourself a favour - read the manual:
you can do the requested with basic firewall rules
I know about Firewall rules but the question was is it possible to control with the user name bcz i will have a pool for the remote ip and it will be dhcp pool. so i wont be able to control with a particular ip .
Do you have any comments for this Mr. Normis
Sishith Asok
you could make a firewall chain with all the requested rules, then specify this chain in the ppp profile’s “outgoing-filter” setting, and use a specific profile for each group of users. or maybe some other way
HI,
I have PPP Users like test1,test2,test3 etc.., and the remote address i am using from dhcp Pool so i cant put the rule according to ip. i need to use the username for putting the rule. so can anybody suggest..
I need to control with Username .. Is it possible… Veryy Urgent
Sishith
  1. Add static pptp interfaces for specific users and apply rules to each as needed
  2. Assign static IP’s to specific users instead of the pool method and apply rules as needed
HI,
Thanks for the response but is there any way i can control with the user name ,if i am assigning the remote address as dhcp pool.
Sishith Asok R
Yes, create named interfaces for each person, this way you have a static interface for them. Then in firewall filters you can use this interface - anything coming or going from their ‘tunnel’. You should try to use the ppp-in and ppp-out chains to your advantage as well (ppp chain is dynamically added, I like to use ppp-in and ppp-out as well)
Sam
