VPN Issues 7.11.2
Hi All
Still new to MT’s. I have have an Hex s on the 330/50 fttp connection. When it arrived I upgraded to V7 (not sure what that was now) and was getting about 280mb download and running multiple ipsec vpn’s.
Was was told be a friend to install the latest as it fixed fasttrack and made the connection quicker. I did this to 7.11.2 and speed test were good coming in at around 320mb downloads but the vpns traffic is shockingly slow. Takes 2 minutes to rdp to a server which is normally seconds and it/s not click and wait.
If I turn off fasttrack in the firewall I now get around 230mb download speed by the vpn’s are back to normal.
Can anyone advise me on the issue I may have as sure I have done something wrong somewhere, but it was fine on the original v7 firmware
Thanks in advance
Glenn
Check that VPN connections are excluded from FastTrack, it’s a mandatory rule for correct working of VPN.
Ok any thanks. Just need to work that bit out
Gald it not me going mad
Cheers
Ok found this incase anyone comes across this with the same issue. Fixed for me
https://rants.tech/mikrotik-fasttrack-configuration-with-l2tp-ipsec-vpn/
