vpn kerio control
hi,
how to make vpn between mikrotik rb951ui-2nd and kerio control ?
mikrotik is connected to internet via huawei usb 3g stick and have dynamic ip
kerio have static ip
thanx
i really need help
this can be work ?
I’d say no. From http://kb.kerio.com/product/kerio-control/vpn/configuring-kerio-vpn-server-1305.html:
Kerio Control supports VPN (Virtual Private Network). Kerio Control includes a proprietary implementation of VPN, called Kerio VPN.
Edit: On second look, they also have IPSec (http://kb.kerio.com/product/kerio-control/vpn/configuring-ipsec-vpn-tunnel-1288.html), so the answer for that should be yes.
but in the page is connect via static ip address
i have on microtik dynamic ip ( 3g modem )
From screenshots on that page, I’d say that you want to choose “Passive - it only accepts incoming connections” as starting point. But I can’t help you with further details, because I’m not familiar with Kerio (and most people on this forum probably aren’t either).
