Has anyone got VPN - L2TP/IPSEC to work in RouterOS 6.16 and above could share their setup? I have been unable to get this working now for quite awhile and I am now on Router OS 6.22. I would like to see screen shots with private info blotted out of course. Ever since Mikrotik changed generate policy from simple yes/no to (no, port strict, port override) problems arises. Thank you!
Thank you…I will try your setup later. Also, wondered if you had Android, IOS as well as Mac’s as client…those are the devices I mostly use.
It’s just sad that Mikrotik won’t have proper instructions with modern day menu driven that folks with home offices can use to set up VPN that they connect to their home office from anywhere in the world with any device through an unknown router or IP address, and the only Mikrotik involve is the one at my home office.
My Droid connects using the standard settings.
The only problem I have is that I need to add an input rule to the firewall to allow the IP address I get from my carrier since my last input rule is block anything not specified to pass.
I don’t know a way around this.
Wondered if a rule that accepts the MAC address of your device would work…seems that it should. All my connections would be via the web.
The MAC accept input rule did work, I thought I had tried that before. I never could get my Droid Razr M to work, but my Droid mini hooked up the first time.
After further testing the only mac address that works is the wifi address of the Droid. I can’t connect with my Mifi or Droid’s LTE network.
