VPN l2tp, scope via and PCC
Hello!
We have 2 internet providers, named ‘dialog’ and ‘etype’.
Internet access throw this providers is checking using scope via 8.8.8.8 and 8.8.4.4 and balanced by PCC (Per Connection Classifier).
add check-gateway=ping distance=1 gateway=8.8.8.8 routing-mark=dialog-route
add check-gateway=ping distance=2 gateway=8.8.4.4 routing-mark=dialog-route
add check-gateway=ping distance=1 gateway=8.8.4.4 routing-mark=etype-route
add check-gateway=ping distance=2 gateway=8.8.8.8 routing-mark=etype-route
add distance=1 dst-address=8.8.4.4/32 gateway=109.237.2.73 scope=10
add distance=10 dst-address=8.8.4.4/32 type=blackhole
add distance=1 dst-address=8.8.8.8/32 gateway=83.219.140.209 scope=10
add distance=10 dst-address=8.8.8.8/32 type=blackhole
add address=192.168.0.1/24 comment=defconf interface=bridge_LAN network=192.168.0.0
add address=83.219.140.210/30 interface=05-ISP-Dialog network=83.219.140.208
add address=109.237.2.74/30 interface=04-ISP-Etype network=109.237.2.72
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=bridge_LAN new-connection-mark=dialog-conn per-connection-classifier=src-address:2/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=bridge_LAN new-connection-mark=etype-conn per-connection-classifier=src-address:2/1
add action=mark-routing chain=prerouting connection-mark=dialog-conn dst-address-type=!local new-routing-mark=dialog-route passthrough=no
add action=mark-routing chain=prerouting connection-mark=etype-conn dst-address-type=!local new-routing-mark=etype-route passthrough=no
add action=mark-routing chain=output connection-mark=dialog-conn new-routing-mark=dialog-route passthrough=no
add action=mark-routing chain=output connection-mark=etype-conn new-routing-mark=etype-route passthrough=no
add action=mark-connection chain=prerouting in-interface=05-ISP-Dialog new-connection-mark=dialog-conn passthrough=no
add action=mark-connection chain=prerouting in-interface=04-ISP-Etype new-connection-mark=etype-conn passthrough=no
add action=masquerade chain=srcnat comment="Allow Internet" dst-address=!192.168.0.0/24 out-interface-list=ISP src-address=192.168.0.0/24
We have splited IP dhcp pool for local and VPN users:
add name=dhcp_local_pool ranges=192.168.0.31-192.168.0.229
add name=vpn_pool ranges=192.168.0.230-192.168.0.249
add add-arp=yes address-pool=dhcp_local_pool authoritative=after-2sec-delay disabled=no interface=bridge_LAN lease-time=30m name=dhcp_srv_local
VPN is l2tp
/ppp profile
set *0 bridge=bridge_LAN
add bridge=bridge_LAN change-tcp-mss=yes local-address=192.168.0.1 name=office_vpn remote-address=vpn_pool use-compression=no use-encryption=yes use-mpls=no use-upnp=no
set *FFFFFFFE insert-queue-before=first parent-queue=none queue-type=default use-compression=yes use-encryption=default
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=office_vpn enabled=yes use-ipsec=yes
The problem is that VPN users can’t connect. Error:
Full config.
More error log.
If I use “classik” routing (without routing-mark and scope) VPN is ok.
