Hi everybody,
I’m having some difficulties to make a lan to lan vpn. My actual scenario is like that:
As you can see, there is a central office with a mikrotik with lan configured to 192.168.1.x . Remote sites are also lan configured to 192.168.1.x . As there is some devices in remote sites that didn’t need VPN and cannot be configured with another subnet I installed a second Mikrotik router so I can setup a VPN to Central Office. Also as window server in remote site cannot be stopped for a long time I added a second IP to ethernet adapter so this machine keeps internet connectivity via ISP Router and has a second IP for connecting via Mikrotik VPN.
The point is that I setup vpn (SSTP or PPtP, both works) and I can ping from Central Office to Remote Mikrotik 192.168.10.10 but cannot ping Windows Server 192.168.10.2. Tried with proxy-arp and local-proxy-arp but didn’t work.
I appreciate if someone could help to setup this VPN. I don’t bother to change the approach but cannot change LAN subnets from 192.168.1.x
Thanks in advance!
