Hi serjejs, thx for your time.
I review all firewall rules, and I could not be able to find a problematic rule.
Is rare, the the netwotch is not working, because for the MKT the VPN is allways out of service.
All the systems are working perfectly, but from one MKT to the other trhough the VPN, are unreachable.
Let me show you the Filter table:
0 ;;; Knock Security Port
chain=input protocol=tcp dst-port=1337 action=add-src-to-address-list address-list=Knock address-list-timeout=15s
1 chain=input protocol=tcp dst-port=7331 src-address-list=Knock action=add-src-to-address-list address-list=Safe address-list-timeout=15m
2 ;;; Port scanners to list
chain=input protocol=tcp psd=20,3s,3,1 action=add-src-to-address-list address-list=Port Scanners address-list-timeout=2w
3 ;;; SYN/FIN scan
chain=input protocol=tcp tcp-flags=fin,syn action=add-src-to-address-list address-list=Port Scanners address-list-timeout=2w
4 ;;; SYN/RST scan
chain=input protocol=tcp tcp-flags=syn,rst action=add-src-to-address-list address-list=Port Scanners address-list-timeout=2w
5 ;;; FIN/PSH/URG scan
chain=input protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack action=add-src-to-address-list address-list=Port Scanners address-list-timeout=2w
6 ;;; NMAP FIN Stealth scan
chain=input protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg action=add-src-to-address-list address-list=Port Scanners address-list-timeout=2w
7 ;;; NMAP NULL scan
chain=input protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg action=add-src-to-address-list address-list=Port Scanners address-list-timeout=2w
8 ;;; ALL/ALL scan
chain=input protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg action=add-src-to-address-list address-list=Port Scanners address-list-timeout=2w
9 ;;; Dropping Port Scanners
chain=input src-address-list=Port Scanners action=drop
10 ;;; Dropping DoS Scanners
chain=input protocol=tcp connection-limit=2,32 src-address-list=DoS Scanners action=drop
11 ;;; Denial of Service Hackers to list
chain=input protocol=tcp connection-limit=10,32 src-address-list=!local-addr action=add-src-to-address-list address-list=DoS Scanners
address-list-timeout=1d
12 ;;; MS Virus
chain=forward protocol=tcp dst-port=445 action=drop
13 chain=forward protocol=udp dst-port=445 action=drop
14 ;;; Accept established connections
chain=input connection-state=established action=accept
15 ;;; Drop invalid connections
chain=input connection-state=invalid action=drop
16 ;;; UDP
chain=input protocol=udp action=accept
17 ;;; Allow limited pings
chain=input protocol=icmp limit=5/5s,2 action=accept
18 ;;; Drop excess pings
chain=input protocol=icmp action=drop
19 ;;; Dropping packets not destined to the router itself, including all broadcast traffic
chain=input dst-address-type=!local action=drop
20 ;;; Servicio de DHCP Aceptado
chain=input src-address=0.0.0.0 dst-address=255.255.255.255 protocol=udp dst-port=67-68 action=accept
21 chain=input src-address=0.0.0.0 protocol=udp dst-port=67-68 dst-address-type=local action=accept
22 ;;; Tr fico Local dirigido al Router
chain=input dst-address-type=local src-address-list=local-addr action=accept
23 ;;; FTP (20/21 TCP) - Desde Afuera
chain=input protocol=tcp src-port=1024-65535 dst-port=20-21 action=drop
24 ;;; SSH for management purposes - Desde Afuera
chain=input protocol=tcp dst-port=22 src-address-list=Safe action=accept
25 X ;;; Telnet for management purposes - Desde Afuera
chain=input protocol=tcp dst-port=23 src-address-list=Safe action=accept
26 ;;; Webox for management purposes - Desde Afuera
chain=input protocol=tcp dst-port=80 src-address-list=Safe action=drop
27 ;;; Winbox for management purposes - Desde Afuera
chain=input protocol=tcp dst-port=8291 src-address-list=Safe action=accept
28 ;;; Acceso Via PPTP
chain=input protocol=gre action=accept
29 chain=input protocol=tcp dst-port=1723 action=accept
30 ;;; Acceso Via VPN
chain=input protocol=ipsec-esp action=accept
31 ;;; VPN
chain=input src-address=65.167.92.190 protocol=udp dst-port=500 action=accept
32 X ;;; Log and Drop All other External Services
chain=input action=log log-prefix=“Drop Externo:”
33 ;;; Log and Drop All other External Services
chain=input action=drop
34 ;;; Accept established connections
chain=forward connection-state=established action=accept
35 ;;; Accept related connections
chain=forward connection-state=related action=accept
36 ;;; Drop all traffic that goes to multicast or broadcast addresses
chain=forward dst-address-type=broadcast,multicast action=drop
37 ;;; Auth Services Rejected
chain=forward protocol=tcp dst-port=113 action=reject reject-with=icmp-network-unreachable
38 X ;;; Bloqueamos NET BIOS
chain=forward protocol=udp dst-port=137-138 src-address-list=local-addr action=drop
39 ;;; DHCP Habilitado
chain=forward connection-mark=DHCP_CON action=accept
40 ;;; DNS
chain=forward connection-mark=DNS_CON action=accept
41 ;;; Servicio de VoIp
chain=forward connection-mark=VOIP_CON action=accept
42 chain=forward protocol=udp dst-port=5000-50000 action=accept
43 ;;; FTP (20/21 TCP)
chain=forward connection-mark=FTP_CON src-address-list=local-addr action=accept
44 ;;; Winbox (8291/TCP)
chain=forward connection-mark=WBOX_CON action=accept
45 ;;; ICMP - Interno
chain=forward protocol=icmp src-address-list=local-addr action=accept
46 ;;; Trafico Web
chain=forward connection-mark=HTTP_CON action=accept
47 ;;; MSN (1763/TCP)
chain=forward connection-mark=MSN_CON action=drop
48 ;;; POP3 (110/TCP)
chain=forward protocol=tcp dst-port=110 action=accept
49 ;;; SNMP (161/UDP)
chain=forward protocol=udp dst-port=161 action=accept
50 ;;; NBT (137-139 / TCP)
chain=forward connection-mark=NBT_CON action=accept
51 ;;; NTP (123/UDP)
chain=forward connection-mark=NTP_CON action=accept
52 ;;; KNOCK (1337 - 7331 / TCP)
chain=forward connection-mark=KNOCK_CON action=accept
53 ;;; CASHCODE SERVER (31155 / TCP)
chain=forward protocol=tcp connection-mark=CASHCODE_CON action=accept
54 ;;; Tr fico a otras redes por PPTP
chain=forward connection-mark=PPTP_CON action=accept
55 ;;; Trafico P2P
chain=forward connection-mark=P2P_CON action=reject reject-with=icmp-network-unreachable
56 ;;; anti-spam policy
chain=forward protocol=tcp src-port=1024-65535 dst-port=25 action=jump jump-target=smtp-first-drop
57 chain=smtp-first-drop src-address-list=first-smtp action=add-src-to-address-list address-list=approved-smtp address-list-timeout=8h
58 chain=smtp-first-drop src-address-list=approved-smtp action=return
59 chain=smtp-first-drop action=add-src-to-address-list address-list=first-smtp address-list-timeout=8h
60 chain=smtp-first-drop action=reject reject-with=icmp-network-unreachable
61 ;;; Tr fico entre Redes Confiables - OK
chain=forward src-address-list=safe-addr dst-address-list=safe-addr action=accept
62 ;;; MAIL (25 - 110 / TCP)
chain=forward connection-mark=MAIL_CON action=accept
63 ;;; Log and Drop All other Local Services
chain=forward action=log log-prefix=“WEB:”
64 chain=forward action=drop
Thanks a lot for your help.
Regards,
