VPN - no access to local lan
MT RB941-2nD
It has loadbalancing and failover configured. I created VPN pool and route for VPN users.
Bridge Arp is set to proxy-arp, but i cannot ping anything else except mikrotik.
If i traceroute vpn ip from any local device it comes to mikrotik ip and stops, same thing if i do that from vpn device to local device.
Even tried suggestions from this topic http://forum.mikrotik.com/t/pptp-connection-cant-ping-anything-mikrotik/34682/1 ,and anything else i could find on the net but it doesn’t work, unfortunately.
My configuration is attached.
Any help would be great!!! Thanks!
conf.txt (2.83 KB)
Solved!!!
Just needed to configure route rule for vpn pool!
Why you should be able the Arp is set to proxy-arp
