VPN not accepting connections
I would like to set up a VPN server on my RouterBoard, and I would like to connect to it from outside using a standard Windows 7 PC.
I have been following this guide:
http://www.mikrotik.com/testdocs/ros/3.0/vpn/pptp.php
The PPTP setup seems pretty straight forward:
Add a user:
[admin@PPTP-Server] ppp secret> add name=user password=passwd \
\... local-address=10.0.0.1 remote-address=10.0.0.2
Enable the PPTP server:
[admin@PPTP-Server] interface pptp-server server> set enabled=yes
I think I have setup up the PPTP server properly but it still doesn’t accept connections from the outside.
Is there anything else I need to set up to let my router accept connections from the outside? My network is very basic: internet - routerboard - internal lan
Hi, Post here please
/ip address print
and
/ip firewall service-port print
[admin@MikroTik] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; default configuration
     192.168.0.254/24   192.168.0.0     ether2-local-master
 1 D 80.99.10.xxx/21    80.99.8.0       ether1-gateway
[admin@MikroTik] > /ip firewall service-port print
 #   NAME        PORTS
 0   ftp        21
 1 X tftp        69
 2 X irc        6667
 3 X h323
 4 X sip        5060
        5061
 5 X pptp
Note: enabling pptp in this menu doesn’t make a difference.
enable it anyway
please post
/ip firewall export
Here is it:
# jan/18/2012 15:06:46 by RouterOS 5.9
# software id = ZRZ7-X4SW
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no \
    protocol=icmp
add action=accept chain=input comment="default configuration" \
    connection-state=established disabled=no in-interface=ether1-gateway
    connection-state=related disabled=no in-interface=ether1-gateway
add action=drop chain=input comment="default configuration" disabled=no \
add action=masquerade chain=srcnat comment="default configuration" disabled=\
    no out-interface=ether1-gateway
add action=dst-nat chain=dstnat disabled=no dst-port=9876 in-interface=\
    ether1-gateway protocol=tcp to-addresses=192.168.0.1 to-ports=3389
add action=dst-nat chain=dstnat disabled=no dst-port=21 in-interface=\
add action=dst-nat chain=dstnat disabled=no dst-port=5000-5100 in-interface=\
add action=dst-nat chain=dstnat disabled=no dst-port=9999 in-interface=\
    ether1-gateway protocol=tcp to-addresses=192.168.0.1 to-ports=80
add action=dst-nat chain=dstnat disabled=no dst-port=6662 in-interface=\
    ether1-gateway protocol=udp to-addresses=192.168.0.1
add action=dst-nat chain=dstnat disabled=no dst-port=22 in-interface=\
set ftp disabled=no ports=21
set tftp disabled=yes ports=69
set irc disabled=yes ports=6667
set h323 disabled=yes
set sip disabled=yes ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
After enabling pptp service in IP->Firewall->Service Port you still no luck with connection to your PPTP server or you just cannot reach 192.168.0.0/24 network?
If you cannot reach 192.168.0.0/24 you just need to add a new route to 10.0.0.0/24 with ether2-local-master as gateway.
My problem is that it seems that the ports on the router itself doesn’t open up for the outside world. Port forwarded ports work perfectly.
Before, all the ports I used were forwarded to a server behind the router, for FTP, remote desktop, etc. Those ports work perfectly and show up as open ports.
However, whatever ports I choose to open on the router doesn’t seem to open up. For example I enabled the SSTP server on port 443. I would think that it would open up port 443 for the outside, but it doesn’t. It does open up 443 for the inside, however. I used some online open port check tool to test for the open ports and it reports 443 as closed.
That Firewall \ Service port actually doesn’t seem to do anything. No matter if I disable or enable FTP, I can FTP to the router from the inside network.
Update: I even tried adding a NAT rule to direct 443 to the router, but the port is still closed.
Update2: I found a guide for SSTP and it says the following line: “Don’t forget to open this port on the firewall (on the INPUT chain) if you are blocking ports by default.”
Can you tell me if I need to do it and if yes, how can I do it? I still have the same /ip firewall filter configuration as above.
Update3: Is this what I need?
http://blog.phipps.at/2011/04/25/howto-configure-a-pptp-server-on-routeros/
[root@Router] > ip firewall filter add chain=input protocol=tcp dst-port=1723 \
                in-interface=eth1-WAN src-address-list=VPN-Users action=accept
[root@Router] > ip firewall filter add chain=input protocol=gre \
These rules are OK:
For PPTP also set on LAN interface ‘arp=proxy-arp’.
HTH,
OK, connection success! I had to open up tcp 1723 and gre on the input chain!
My problem however is that even though I could connect, I have no real connection. In windows, my VPN adapter gets subnet mask: 255.255.255.255 and gateway 0.0.0.0. Is this normal?
How can I set up this arp proxy?
