VPN Not working Using Private WAN
My ISP has given me a private WAN address. My static IP is on the ISP router which forwards to my WAN.
So for example:
My Public: 216.1.1.1
My WAN: 10.0.192.161
When I try and make a VPN tunnel the remote router (LinkSys RV042) has in the VPN log:
“Expected 216.1.1.1 but got 10.0.192.161”
Then it gives up as it thinks it got the wrong address.
I believe the ISP actually NATs that IP to me at their internet gateway.
Does anyone know how to get around this?
thanks for any help!
Sounds like a very odd public addr. Did you check e.g. http://www.whatismyip.com/
rgs Pilgrim
I didnt put the real Public IP. I should have said 216.x.x.x
The connection works great except for VPN ipsec connections.
I think your ISP needs to check his router setup and allow VPN passthrough.
rgs Pilgrim
