VPN or EoIP but how
I need some help with an issue.
A-side. There is one LAN that has a mikrotik router with ppp to the ISP and and wi-fi connects to the B-side and BPG to exchange the routing tables with the other side.
B-side. The is a LAN with a mikrotik router that has wi-fi to connect to A-side with BGP and get Internet from the A-side.
My problem is with a p2p application that exchanges udp packets, the fist machine is on the A-side and the second machine is on the B-side. The application doesn’t work because in the packet headers of the udp connections vice verca the ip of the wi-fi appears.
A VPN is the solution ?
Let’s say I setup a VPN, the 2 machines will communicate as they were on the same place in an 192.168.0.0/24 network ?
Please give me some help !
Thanks a lot !!!
any help ?
i created a pptp tunnel, and I assign static ip that match the tunnel network on both sides machines and they cannot communicate.
please help !!
thanks a lot !
create a EOIP tunnel between them and bridge it with the lan interface.
That will make it like they are in the same physical location.
could you plz write me a howto for EOIP?
I saw an EOIP in the wiki but I don’t know how to do it exactly.
Eoip is simple.
just create the interface, the remote address will be the ip address of the other side of the tunnel and match the tunnel id’s
Then just create a bridge, and add both ports to it.
It is all simply done through winbox.
Have a look at this post http://forum.mikrotik.com/t/can-i-use-bonding-for-pinging-2-pcs/23868/1
