Hello guys
I set up PPTP VPN connection. My clients can connect to VPN, but something strange i happenig. When I am trying to ping anything, I have only access to gateway (192.168.88.1). I can’t access anything else from my network.
Here are some screens with my configuration:
So your gateway is 192.168.88.1, correct?
What range is the VPN IP pool in?
If it is in the 192.168.88.0/24 range as well, you’ll either have to set your local bridge to proxy-arp or (even better) give your VPN pool a seperate IP range (like 192.168.90.0/24).
-Chris
Write ip pool?
And should add your pool in firewall nat and action masquerade.
And in pptp server don’t select “chap, pap” select only mschap1 mschap2.
http://l2tp.patokatech.com/
This is my setup for L2TP VPN, maybe you’ll find something that will help, I don’t mess with PPTP.
