VPN/PPP Problem
I have an interesting problem and I’m really sure it’s a misconfigured Windows 2003 server. Now, let me explain :slight_smile:
The Mikrotik uses the RADIUS authentication from a Windows 2003 server. PPTP connections worked well until a configuration change was made. Here’s the log:
may/06/2006 19:10:19 pptp,info TCP connection established from x.x.x.x
may/06/2006 19:10:19 pptp,ppp,info <pptp-0>: waiting for call...
may/06/2006 19:10:21 pptp,ppp,info <pptp-userX>: authenticated
may/06/2006 19:10:21 pptp,ppp,info <pptp-userX>: terminating... - call cleared
may/06/2006 19:10:21 pptp,ppp,info <pptp-userX>: disconnected
Has anyone run into this before? The Windows VPN client (from my laptop) gives “Error 778: It was not possible to verify the identity of the server”
I can provide more information upon request…
Thanks!
Back out the configuration change; does it work again?
Need to see the IAS logs from the 2003 box.
Regards
Andrew
I was traped in the same problem.and i my windows XP give out the error:"619…"at last i fugure out that because our compus network has been drop any data through port 1723.
Logs as follows:
172.26.10.254,bmenking,05/08/2006,21:24:32,IAS,VPI,6,2,7,1,5,58,61,5,31,66.191.238.9,30,64.89.90.7,32,MikroTik,4,172.26.10.254,26,0x00003A8C09087670696E6574,4108,172.26.10.254,4116,0,4128,Mikrotik,4120,vpinet,4155,0,4154,Use Windows authentication for all users,25,311 1 172.26.10.1 05/06/2006 03:59:54 29,4136,1,4142,0
172.26.10.254,bmenking,05/08/2006,21:24:32,IAS,VPI,25,311 1 172.26.10.1 05/06/2006 03:59:54 29,4154,Use Windows authentication for all users,4155,0,4128,Mikrotik,4116,0,4108,172.26.10.254,4136,2,4142,0
172.26.10.254,bmenking,05/08/2006,21:24:32,IAS,VPI,6,2,7,1,5,58,61,5,31,66.191.238.9,30,64.89.90.7,25,311 1 172.26.10.1 05/06/2006 03:59:54 29,44,81a00000,8,172.26.10.191,45,1,40,1,32,MikroTik,4,172.26.10.254,41,0,26,0x00003A8C09087670696E6574,4108,172.26.10.254,4116,0,4128,Mikrotik,4120,vpinet,4154,Use Windows authentication for all users,4136,4,4142,0
172.26.10.254,bmenking,05/08/2006,21:24:32,IAS,VPI,6,2,7,1,5,58,61,5,31,66.191.238.9,30,64.89.90.7,25,311 1 172.26.10.1 05/06/2006 03:59:54 29,44,81a00000,8,172.26.10.191,45,1,46,0,42,0,52,0,47,0,43,10,53,0,48,1,40,2,49,1,32,MikroTik,4,172.26.10.254,41,0,26,0x00003A8C09087670696E6574,4108,172.26.10.254,4116,0,4128,Mikrotik,4120,vpinet,4154,Use Windows authentication for all users,4136,4,4142,0
I realize that something got messed up in the configuration (W3K side) but maybe these logs will tell you something I’m now seeing. Thanks!
Well, unless you tell me (and I’m sure others) what goes on in those logs (I love Microsoft -grin-), we’re not going to get any wiser there.
However, -rant- pasting your exact error message, copied & pasted into google: http://www.pcreview.co.uk/forums/thread-1574610.php
It would seem that you are using certificates for authentication, and that the CA Root has problems authenticating the certificates - this is a W3K issue, not Mikrotik.
Spend some time on google, I doubt you’re going to get much help here on the MS side of things…
C
I already checked on Google before I posted (I hate forums, I want instant results) and attempted several solutions, one being that exact link. If that had worked, I wouldn’t be posting here :slight_smile:
Anyway, as in my previous post, I realize that this is a W3K problem, not Mikrotik. My interest is whether or not someone has already dealt with this…
Well, this is definately a CA issue. Have you perhaps tried PAP authentication instead? Yes, it’s more insecure, but eleminate things untill you can pin point exactly what’s wrong… :slight_smile:
Other than that, if you can tell me what is what in those log files so that I understand it, I’d be happy to toss my brain at it again..
C
The IAS logs show an IAS_SUCCESS return code (researching that, it’s M$; could mean the function failed successfully). Since Mikrotik is logging a “call cleared” when terminating, is there a way to increase the verbosity of ppp logs on Mikrotik? Maybe I can get a more detailed idea of what is happening.
Thanks!
Your comments about the log just put a smirk on my face, no phun intended :smiley:
/system logging add topics=ppp,debug action=echo
Something like that… Just play arround in /system logging… It’s relatively easy to beef up the logging.
C
EDIT: Just a thought, but if you are using certificates for authentication, should these not be installed on MT ?? Just a thought I had…
I don’t recall using certs or installing them on MT. It originally worked out of the box… .until the W3K server got (re)configured. Then it broke.
Thanks for the logging help!
You know what? I should be looking at the RADIUS interaction between W3K radius and MT.
VPN Client <--> MT <--(radius)--> W3K
Would I be safe in saying that pptp has nothing to do with the interaction between MT and W3K RADIUS? MT should be handling all the nasty ppp stuff… right?
Yes. Provided, the NAS (ie. MT) is configured correctly to accommodate what Radius tells it to do… Now, if nothing changed on MT (your update? was only on Windows?), I’d definately focus on the Windows side of things…
