VPN PPTP can't connect to IPSec IKEv2
Hai member,
I have a problem regarding the PPTP VPN setting that cannot connect to IPsec.
The explanation is like this:
all clients want to be connected to the server with the ip address 172.16.10.2/24, I also set the IPSec from the Surabaya router to the Jakarta router, for clients connected to the Jakarta router, namely the ip address 192.168.20.2/24, it can be connected properly, but for connections client connected to PPTP VPN cannot connect. What should I do so that PPTP VPN can connect to IPSec?
Thank you very much
Regard,
Yusuf
I’m afraid PPTP dos not support encryptions and it’s not good idea to use it. Use L2TP instead. L2TP uses ipsec encryption beside username and password authentication. Very secure and easy to use.
