hello,
i have VPN PPtp client direct dial from windows xp and can play block ip online game…
when i dial from mikrotik PPtp client,i can’t play online game ( IP Blocked ) ?
here this setting :
1.Dial pptp client from mikrotik – > Success
2.Make nat out interface to pptp out client masqurade —> Success
3.make mangel prerouting markrouting to VPN client ----> Success
4.Make statsic routing gateway pptp-out and routing mark VPN Client -----> Success
I want local PC only can use VPN client gateway if they dial up to vpn l2tp mikrotik server:
6.make L2tp server enable —> success
7.make secret and profile ----> success
In client ( local PC Windows)
5.Local PC connect to VPN L2tp server mikrotik ----> Success
6. IP Public local PC use VPN client gateway —> success ( check by open whatismyipaddress.com and speedtest.net )
and when to play game online get IP Blocked
where my wrong ?
is there a difference in a direct dial vpnserver from windows or using mikrotik dial client pptp and use nat
Thanks for advice
