i need to config PPTP server using my router board 952 and when i connect using vpn from my pc windows 10 and can’t reach my local network e.g my dvr 192.168.7.10 and can only access the routerboard , and below is the export from my router board
add arp=proxy-arp name="BR - DHCP" protocol-mode=none
add name="BR - MGM" protocol-mode=none
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=\
10.25.240.170 name="01 - Main"
set [ find default-name=ether2 ] advertise=\
192.168.7.10 name="02 - DVR"
set [ find default-name=ether3 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name="03 - "
set [ find default-name=ether4 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name="04 - "
set [ find default-name=ether5 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name="05 - "
/interface pppoe-client
add add-default-route=yes disabled=no interface="BR - MGM" keepalive-timeout=\
disabled name=pppoe-out1 password=nnn user=n@n
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap eap-methods="" \
management-protection=allowed mode=dynamic-keys name=profile1 \
supplicant-identity="" wpa-pre-shared-key=12345678 wpa2-pre-shared-key=\
12345678
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no hide-ssid=yes mode=ap-bridge name="wlan1 - 2G" \
security-profile=profile1 ssid=MikroTik2G
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
disabled=no hide-ssid=yes mode=ap-bridge name="wlan2 - 5G" \
security-profile=profile1 ssid=MikroTik5G
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.7.100-192.168.7.254
add name="VPN Pool" ranges=192.168.7.50-192.168.7.60
add address-pool=dhcp_pool0 disabled=no interface="BR - DHCP" name=dhcp1
/ppp profile
add dns-server=8.8.8.8 local-address=192.168.7.1 name=profile1 remote-address=\
"VPN Pool"
add bridge="BR - DHCP" hw=no interface="02 - DVR"
add bridge="BR - DHCP" hw=no interface="03 - "
add bridge="BR - DHCP" hw=no interface="04 - "
add bridge="BR - DHCP" hw=no interface="05 - "
add bridge="BR - DHCP" interface="wlan1 - 2G"
add bridge="BR - DHCP" interface="wlan2 - 5G"
add bridge="BR - MGM" hw=no interface="01 - Main"
/interface pptp-server server
set authentication=mschap2 enabled=yes
add address=10.25.240.171/24 interface="01 - Main" network=10.25.240.0
add address=192.168.7.1/24 interface="BR - DHCP" network=192.168.7.0
add address=192.168.7.0/24 dns-server=109.224.14.2,109.224.14.3 gateway=\
192.168.7.1
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input protocol=gre
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=R7 passthrough=yes \
src-address=192.168.7.0/24
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=\
192.168.7.0/24
add distance=1 gateway=pppoe-out1 routing-mark=R7
add distance=1 dst-address=10.25.240.0/24 gateway="BR - MGM" routing-mark=R7
add distance=1 dst-address=192.168.7.0/24 gateway="BR - DHCP" routing-mark=R7
add distance=1 gateway=10.25.240.1
add distance=1 dst-address=216.239.35.12/32 gateway=pppoe-out1
/ppp secret
add name=abdulnoor password=11111111 profile=profile1
