4drik
December 16, 2019, 2:28pm
1
Hello.
I would like to set up a VPN.
I found a video tutorial: https://www.youtube.com/watch?v=8SvfARW469E
PPP → Interface → PPTP Server → Enabled → OK
IP → Pool → + → PPTP_Pool, 192.168.2.10-192.168.2.100 → OK
IP → Firewall → NAT → Chain: srnat, Srcadress: 192.168.2.0/24 → Action → Action: masquerade
PPP → Profiles → PPTP Profile, Local address: 192.168.0.85, Remote Address: PPTP_Pool → OK
PPP → Secret → + → Name: VPNName, Password: VPNPassword, service: pptp, Profile: PPTP_Profile->OK
It’s working well inside the Network but I can’t connect to a VPN from outside the network.
I added:
/ip firewall filter add chain=input protocol=tcp dst-port=1723 action=accept comment=“Allow IN PPTP/TCP1723” disabled=no
/ip firewall filter add chain=output protocol=tcp dst-port=1723 action=accept comment=“Allow OUT PPTP/TCP1723” disabled=no
/ip firewall filter add chain=input protocol=gre action=accept comment=“Allow IN PPTP/GRE” disabled=no
/ip firewall filter add chain=output protocol=gre action=accept comment=“Allow OUT PPTP/GRE” disabled=no
but unfortunately it didn’t help
I also found this:
/ip firewall service-port enable pptp
But it didn’t help either. I am running out of ideas, please help.
When answering, please take into account that I’m just starting my adventure with MikroTik.
I wish you gifts like this!
Anumrak
December 16, 2019, 2:39pm
2
Hey! Congratulations! Have you enabled PPTP server, added user, configured local and remote addresses?
4drik
December 16, 2019, 2:49pm
3
Thank you.
I have definitely enabled PPTP server.
I don’t know if I added an user but I added a profile with an IP pool:
Is that what you meant?
How can I check the configuration of local and remote addresses?
Everything I did - I described it in first post.
@Anumrak
Oh, user is a secret, then yes, I added:
Can you please explain why you chose PPTP over (i.e.) L2TP IPSEC?
4drik
December 17, 2019, 7:16am
5
Hello.
I read in an article that PPTP is the easiest method to configure.
Still, I can’t connect from outside the Network.
I’ve found that I got no Default Gateway after connect to VPN (inside the Network):
Does this bring us closer to solution?
karlisi
December 17, 2019, 8:20am
6
I added:
You don’t need output rules for PPTP server, all outgoing connections will be related or .
Are your input rules before default input drop all rule?
Local address and remote address should be from same subnet, they need to talk to each other.
4drik
December 17, 2019, 9:33am
7
I just wanted to write that this is it.
I added these rules from the terminal, and the terminal always adds positions at the end.
Such a simple matter, and so much torment.
Thank you.
