Hello Guys,
Please Help me out to solve my VPN Configuration.
I have created VPN through PPTP. The Configuration Mentioned below.
VPN Server.
WAN IP - 59.160.X.X/27
LAN IP - 172.16.97.X/23
VPN Client
WAN IP - 202.160.X.X/29
LAN IP - 172.16.2.X/23
Tunnel IP
Server - 10.10.10.1
Client - 10.10.10.2
Now, The Tunnel is established.
Route Added
Server - dst-address=172.16.2.0/23 gateway=10.10.10.2
Client - dst-address=172.16.97.0/23 gateway=10.10.10.1
I Can Able to ping the VPN Client Network from VPN Server Network. But I cant able to ping VPN Server Network from Client Network, even i cant able tp ping 10.10.10.1.
It sounds like the routing table isn’t correct. Can you post your routing table from both mikrotiks?
You need to have a route in the VPN concentrator for the remote network, and a route in the VPN client router to the concentrators network. Since this is a PPTP link setup the PPP secret to create the route dynamically when the PPTP link is up.
You’ll still have to add a static route on the remote end. There’s no need for Proxy-ARP.
I have a similar PPTP link connecting a remote office to our main office. I can post the configs if need be.
Not sure what the 10.10.10.xxx network is used for, the VPN client end should be assigned an address from your 172.16.2.xx pool, and their should be a route from that address to the remote network and vise-versa.
This post may be a little confusing I have a sample config I can post later.
PPTP Server routing table. The PPTP link has a statically assigned address through the PPP secrets and I just created static routes in the routing tables. You could also use the routes function in the PPP secrets to have the route added dynamically.
DST-ADDRESS PREF-SRC G GATEWAY DIS INTERFACE
0 ADC 66.xx.xx.xx/32 66.xx.xx.xx pppoe-out1
1 ADC 192.168.0.222/32 192.168.0.199 <pptp-user.remote>
2 ADC 192.168.0.0/24 192.168.0.1 LAN
3 A S ;;; Route to remote office
192.168.1.0/24 r 192.168.0.222 <pptp-user.remote>
4 AD 0.0.0.0/0 r 66.xx.xx.xx 1 pppoe-out1
the client end looks similar just reverse the routes.
