I Have a problem with vpn server, i have 2 Wan and 1 lan
Wan 1 is dinamic ip (ADSL)
Wan 2 is fixed ip (corporate internet)
and my lan
This error on trie connect on Wan 2
When client (mikrotik) trie to connect on my microtik pptp server this error above
this error on log
11:24:35 firewall,info dstnat: in:2-Wan out:(none), src-mac 06:f5:03:xx:xx:xx, proto TCP (SYN), 178.85.159.20:57580->192.168.25.2:1723, len 60
RouterOS 6.39.1
Interface 1-Wan = WAN1
Interface 2-Wan = WAN2
Interface 3-Rede = Lan
add action=drop chain=forward comment="Bloqueio Facebook" content=facebook.com disabled=yes protocol=tcp
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=input comment="defconf: drop all from WAN" disabled=yes in-interface=1-Wan
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface=1-Wan
add chain=input comment="allow tcp 1723 for VPN" dst-port=1723 in-interface=2-Wan protocol=tcp
add chain=input comment="allow tcp 1723 for VPN" dst-port=1723 in-interface=2-Wan log=yes protocol=udp
add action=accept chain=input in-interface=2-Wan protocol=gre
/ip firewall mangle
add action=mark-connection chain=prerouting in-interface=1-Wan new-connection-mark=WAN1_connection
add action=mark-connection chain=prerouting in-interface=2-Wan new-connection-mark=WAN2_connection
add action=mark-routing chain=prerouting connection-mark=WAN1_connection in-interface=3-Rede new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_connection in-interface=3-Rede new-routing-mark=to_WAN2
add action=mark-routing chain=output new-routing-mark=to_WAN1 passthrough=yes src-address=192.168.100.1
add action=mark-routing chain=output new-routing-mark=to_WAN2 passthrough=yes src-address=192.168.25.1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=1-Wan
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=0.89.168.192-255.89.168.192
add action=masquerade chain=srcnat out-interface=1-Wan
add action=masquerade chain=srcnat out-interface=2-Wan
add action=dst-nat chain=dstnat dst-port=1723 in-interface=2-Wan log=yes protocol=tcp to-addresses=192.168.10.1 to-ports=1723
/ip firewall service-port
set pptp ports=1723
add check-gateway=ping distance=1 gateway=192.168.100.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.25.1 routing-mark=to_WAN2
add comment="1-Copel route" distance=1 gateway=192.168.100.1
add check-gateway=ping distance=2 gateway=192.168.25.1
