VPN Problem
i decided to upgrade an old Linksys/Cisco router and i now a have Mikrotik
Problem is that i had a VPN Gateway to Gatwey with another Lynksys router, i setup the Mikrotik but it doesn’t pass phase 2 of authentification it conects phase 1 for 30s but that’s it.
The Linksys router config:
Local security: Ip only
Remote security: Ip only
Keying Mode: Ike with preshared key
Phase1 DH Group: Group 1
Phase1 Encryption: 3DES
Phase1 Authentication: SHA1
Phase1 SA Life Time: 28800 seconds
Perfect Forward Secrecy: Yes
Phase2 DH Group: Group 1
Phase2 SA Life Time: 3600 seconds
Preshared key: secret
and on the Mikrotik i have this config:
nov/29/2019 20:16:41 by RouterOS 6.43.16
software id = GLDH-AY03
model = RB1100Dx4
serial number = blabla
add admin-mac=bla.bla auto-mac=no name=bridge-local
set [ find default-name=ether1 ] comment=isp1 name=ether1-wan
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
set 12 default-vlan-id=0
set 13 default-vlan-id=0
set 14 default-vlan-id=0
set 15 default-vlan-id=0
add comment=“WAN ports” name=WAN
add comment=“LAN ports” name=LAN
/ip ipsec peer profile
set [ find default=yes ] dh-group=
modp8192,modp6144,modp4096,modp3072,modp2048,modp1536,modp1024,modp768
enc-algorithm=aes-256,aes-192,aes-128,3des,des
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512,sha256,sha1,md5,null
enc-algorithms=“aes-256-cbc,aes-256-ctr,aes-256-gcm,camellia-256,aes-192-c
bc,aes-192-ctr,aes-192-gcm,camellia-192,aes-128-cbc,aes-128-ctr,aes-128-gc
m,camellia-128,3des,blowfish,twofish,des,null” pfs-group=modp768
add name=pool-lan ranges=192.168.1.100-192.168.1.190
add address-pool=pool-lan disabled=no interface=bridge-local name=dhcp-lan
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6
add bridge=bridge-local interface=ether7
add bridge=bridge-local interface=ether8
add bridge=bridge-local interface=ether9
add bridge=bridge-local interface=ether10
add bridge=bridge-local interface=ether11
add bridge=bridge-local interface=ether12
add bridge=bridge-local interface=ether13
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether1-wan list=WAN
add address=192.168.1.199/24 interface=bridge-local network=192.168.1.0
add address=192.77.63.18 interface=ether1-wan network=192.77.63.1
/ip cloud
set ddns-enabled=yes
add address=192.168.1.0/24 dns-server=192.168.1.199 gateway=192.168.1.199
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.199 name=router
/ip firewall address-list
add address=192.168.1.0/24 list=Internet
add action=accept chain=input comment=“Accept established,related,untracked”
add action=drop chain=input comment=“Drop invalid” connection-state=invalid
add action=accept chain=input comment=“Accept ICMP” protocol=icmp
add action=accept chain=input comment=“Accept all from bridge-local”
in-interface=bridge-local
add action=accept chain=input comment=“Accept access for ManageIP group”
src-address-list=ManageIP
add action=drop chain=input comment=“Drop all other”
add action=fasttrack-connection chain=forward comment=fasttrack
connection-state=established,related disabled=yes
“accept established,related,untracked” connection-state=
add action=drop chain=forward comment=“Drop invalid” connection-state=invalid
“Accept Internet via ISP1 for Internet group” connection-state=new
in-interface=bridge-local out-interface=ether1-wan src-address-list=
Internet
add action=drop chain=forward comment=“Drop all other”
add action=accept chain=srcnat dst-address=192.168.2.0/24 src-address=
192.168.1.0/24
add action=masquerade chain=srcnat comment=masquerade ipsec-policy=out,none
out-interface-list=WAN
/ip ipsec peer
add address=25.2.198.15/32 comment=Office secret=secret
/ip ipsec policy
add comment=Office dst-address=192.168.2.0/24 sa-dst-address=25.2.198.15
sa-src-address=192.77.63.18 src-address=192.168.1.0/24 tunnel=yes
add distance=1 gateway=192.77.63.1
/system clock
set time-zone-name=RO/RO
/system identity
set name=MyRouter
/tool mac-server
/tool mac-server mac-winbox
i feel like i’m missing something here, but still can’t make-it work.
Thank you for all the help.
You should see the answer in the log. Use /system logging add topics=ipsec,!packet to enable detailed logging of IPsec. Then, disable the peer at Tik side, let it “cool down” for 5 minutes, then run /log print follow-only file=ipsec-startup where topics~“ipsec” and re-enable the peer. Once phase 1 comes up and phase 2 fails, break the /log print … command, download the file and read it.
If you cannot find the reason on your own, post the file here, after anonymizing it the way suggested in my automatic signature right below.
Also, you may want to upgrade the machine from 6.43.16 to 6.44.6 (long-term) if not 6.45.7 (stable). I don’t suggest that the old RouterOS version is the reason why phase 2 fails, but the structure of the IPsec configuration has changed between 6.43 and 6.44, so once you are starting with IPsec on Tik anyway, maybe better to learn the new way already now.
Upgrade the machine, this should solve your issue I think.
Hello, and thank you, i updated the router and bellow is the log for ipsec.
The only thing that pop-up was: 16:43:48 ipsec no IKEv1 peer config for 25.2.198.15
dec/ 2/2019 16:54:50 by RouterOS 6.45.7
16:43:20 ipsec,debug seen nptype=8(hash) len=24
16:43:20 ipsec,debug succeed.
16:43:20 ipsec,debug HASH received:
16:43:20 ipsec,debug 1b17fa92 876eed4c 3b0130bf 2b5d282b a0a8c53c
16:43:20 ipsec,debug HASH for PSK validated.
16:43:20 ipsec,debug 25.2.198.15 peer’s ID:
16:43:20 ipsec,debug 01000000 524d3e18
16:43:20 ipsec,debug ===
16:43:20 ipsec policy installed for connected peer, creating ph2
16:43:20 ipsec,debug (proto_id=ESP spisize=4 spi=00000000 spi_p=00000000 encmode=Tunnel reqid=0:0)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=256 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=256 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=256 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=256 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=256 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=256 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=288 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=256 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=288 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=256 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=288 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=256 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=288 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=256 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=288 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-GCM-ICV16 encklen=256 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-GCM-ICV16 encklen=288 authtype=254)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=256 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=256 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=256 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=256 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=256 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=192 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=192 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=192 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=192 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=192 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=192 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=224 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=192 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=224 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=192 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=224 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=192 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=224 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=192 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=224 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-GCM-ICV16 encklen=192 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-GCM-ICV16 encklen=224 authtype=254)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=192 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=192 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=192 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=192 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=192 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CBC encklen=128 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=128 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=160 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=128 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=160 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=128 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=160 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=128 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=160 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=128 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-CTR encklen=160 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-GCM-ICV16 encklen=128 authtype=254)
16:43:20 ipsec,debug (trns_id=AES-GCM-ICV16 encklen=160 authtype=254)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=0 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=0 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=0 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=0 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=CAMELLIA encklen=0 authtype=254)
16:43:20 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=3DES encklen=0 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=3DES encklen=0 authtype=254)
16:43:20 ipsec,debug (trns_id=BLOWFISH encklen=128 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=BLOWFISH encklen=128 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=BLOWFISH encklen=128 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=BLOWFISH encklen=128 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=BLOWFISH encklen=128 authtype=254)
16:43:20 ipsec,debug (trns_id=TWOFISH encklen=128 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=TWOFISH encklen=128 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=TWOFISH encklen=128 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=TWOFISH encklen=128 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=TWOFISH encklen=128 authtype=254)
16:43:20 ipsec,debug (trns_id=DES encklen=0 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=DES encklen=0 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=DES encklen=0 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=DES encklen=0 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=DES encklen=0 authtype=254)
16:43:20 ipsec,debug (trns_id=NULL encklen=0 authtype=hmac-sha512)
16:43:20 ipsec,debug (trns_id=NULL encklen=0 authtype=hmac-sha256)
16:43:20 ipsec,debug (trns_id=NULL encklen=0 authtype=hmac-sha1)
16:43:20 ipsec,debug (trns_id=NULL encklen=0 authtype=hmac-md5)
16:43:20 ipsec,debug (trns_id=NULL encklen=0 authtype=254)
16:43:20 ipsec,debug begin QUICK mode.
16:43:20 ipsec initiate new phase 2 negotiation: 192.77.63.18[500]<=>25.2.198.15[500]
16:43:20 ipsec,debug hash(sha1)
16:43:20 ipsec,debug call pfkey_send_getspi 17
16:43:20 ipsec,debug pfkey GETSPI sent: ESP/Tunnel 25.2.198.15[500]->192.77.63.18[500]
16:43:20 ipsec,debug pfkey getspi sent.
16:43:20 ipsec,debug dh(modp768)
16:43:20 ipsec,debug use local ID type IPv4_subnet
16:43:20 ipsec,debug use remote ID type IPv4_subnet
16:43:20 ipsec,debug IDci:
16:43:20 ipsec,debug 04000000 c0a80100 ffffff00
16:43:20 ipsec,debug IDcr:
16:43:20 ipsec,debug 04000000 c0a80600 ffffff00
16:43:20 ipsec,debug add payload of len 2736, next type 10
16:43:20 ipsec,debug add payload of len 24, next type 4
16:43:20 ipsec,debug add payload of len 96, next type 5
16:43:20 ipsec,debug add payload of len 12, next type 5
16:43:20 ipsec,debug add payload of len 12, next type 0
16:43:20 ipsec,debug add payload of len 20, next type 1
16:43:20 ipsec,debug 2956 bytes from 82.77.63.24[500] to 82.77.62.24[500]
16:43:20 ipsec,debug 1 times of 2956 bytes message will be sent to 25.2.198.15[500]
16:43:20 ipsec sent phase2 packet 192.77.63.18[500]<=>25.2.198.15[500] 54bb406253f04cf7:a21d7bac23586a6f:0000a11e
16:43:20 ipsec,info ISAKMP-SA established 192.77.63.18[500]-25.2.198.15[500] spi:54bb406253f04cf7:a21d7bac23586a6f
16:43:30 ipsec,debug 2956 bytes from 192.77.63.18[500] to 25.2.198.15[500]
16:43:30 ipsec,debug 1 times of 2956 bytes message will be sent to 25.2.198.15[500]
16:43:30 ipsec resent phase2 packet 192.77.63.18[500]<=>25.2.198.15[500] 54bb406253f04cf7:a21d7bac23586a6f:0000a11e
16:43:40 ipsec,debug 2956 bytes from 192.77.63.18[500] to 25.2.198.15[500]
16:43:40 ipsec,debug 1 times of 2956 bytes message will be sent to 25.2.198.15[500]
16:43:40 ipsec resent phase2 packet 192.77.63.18[500]<=>25.2.198.15[500] 54bb406253f04cf7:a21d7bac23586a6f:0000a11e
16:43:48 ipsec,debug ===== received 92 bytes from 25.2.198.15[500] to 192.77.63.18[500]
16:43:48 ipsec,debug receive Information.
16:43:48 ipsec,debug hash(sha1)
16:43:48 ipsec,debug hash validated.
16:43:48 ipsec,debug begin.
16:43:48 ipsec,debug seen nptype=8(hash) len=24
16:43:48 ipsec,debug seen nptype=12(delete) len=28
16:43:48 ipsec,debug succeed.
16:43:48 ipsec,debug 25.2.198.15 delete payload for protocol ISAKMP
16:43:48 ipsec,info purging ISAKMP-SA 192.77.63.18[500]<=>25.2.198.15[500] spi=54bb406253f04cf7:a21d7bac23586a6f.
16:43:48 ipsec purged ISAKMP-SA 192.77.63.18[500]<=>25.2.198.15[500] spi=54bb406253f04cf7:a21d7bac23586a6f.
16:43:48 ipsec,debug purged SAs.
16:43:48 ipsec,info ISAKMP-SA deleted 192.77.63.18[500]-25.2.198.15[500] spi:54bb406253f04cf7:a21d7bac23586a6f rekey:1
16:43:48 ipsec,debug ===== received 236 bytes from 25.2.198.15[500] to 192.77.63.18[500]
16:43:50 ipsec,debug ===
16:43:50 ipsec,info initiate new phase 1 (Identity Protection): 192.77.63.18[500]<=>25.2.198.15[500]
16:43:50 ipsec,debug new cookie:
16:43:50 ipsec,debug ea04183c7081318c\01
16:43:50 ipsec,debug add payload of len 1552, next type 13
16:43:50 ipsec,debug add payload of len 16, next type 13
16:43:50 ipsec,debug add payload of len 16, next type 0
16:43:50 ipsec,debug 1844 bytes from 192.77.63.18[500] to 25.2.198.15[500]
16:43:50 ipsec,debug 1 times of 1844 bytes message will be sent to 25.2.198.15[500]
16:43:50 ipsec sent phase1 packet 192.77.63.18[500]<=>25.2.198.15[500] ea04183c7081318c:0000000000000000
16:43:50 ipsec,debug ===== received 108 bytes from 25.2.198.15[500] to 192.77.63.18[500]
16:43:50 ipsec,debug begin.
16:43:50 ipsec,debug seen nptype=1(sa) len=60
16:43:50 ipsec,debug seen nptype=13(vid) len=20
16:43:50 ipsec,debug succeed.
16:43:50 ipsec received Vendor ID: DPD
16:43:50 ipsec,debug remote supports DPD
16:43:50 ipsec,debug total SA len=56
16:43:50 ipsec,debug 00000001 00000001 00000030 01010001 00000028 18010000 800b0001 000c0004
16:43:50 ipsec,debug 00015180 80010007 800e0080 80030001 80020002 80040001
16:43:50 ipsec,debug seen nptype=2(prop) len=48
16:43:50 ipsec,debug proposal #1 len=48
16:43:50 ipsec,debug seen nptype=3(trns) len=40
16:43:50 ipsec,debug transform #24 len=40
16:43:50 ipsec,debug type=Life Type, flag=0x8000, lorv=seconds
16:43:50 ipsec,debug type=Life Duration, flag=0x0000, lorv=4
16:43:50 ipsec,debug type=Encryption Algorithm, flag=0x8000, lorv=AES-CBC
16:43:50 ipsec,debug type=Key Length, flag=0x8000, lorv=128
16:43:50 ipsec,debug type=Authentication Method, flag=0x8000, lorv=pre-shared key
16:43:50 ipsec,debug type=Hash Algorithm, flag=0x8000, lorv=SHA
16:43:50 ipsec,debug hash(sha1)
16:43:50 ipsec,debug type=Group Description, flag=0x8000, lorv=768-bit MODP group
16:43:50 ipsec,debug dh(modp768)
16:43:50 ipsec,debug pair 1:
16:43:50 ipsec,debug 0x983f8: next=(nil) tnext=(nil)
16:43:50 ipsec,debug proposal #1: 1 transform
16:43:50 ipsec,debug -checking with pre-shared key auth-
16:43:50 ipsec,debug prop#=1, prot-id=ISAKMP, spi-size=0, #trns=1
16:43:50 ipsec,debug trns#=24, trns-id=IKE
16:43:50 ipsec,debug -compare proposal #1: Local:Peer
16:43:50 ipsec,debug (lifetime = 86400:86400)
16:43:50 ipsec,debug (lifebyte = 0:0)
16:43:50 ipsec,debug enctype = AES-CBC:AES-CBC
16:43:50 ipsec,debug (encklen = 256:128)
16:43:50 ipsec,debug hashtype = SHA:SHA
16:43:50 ipsec,debug authmethod = pre-shared key:pre-shared key
16:43:50 ipsec,debug dh_group = 8192-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #2: Local:Peer
16:43:50 ipsec,debug dh_group = 6144-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #3: Local:Peer
16:43:50 ipsec,debug dh_group = 4096-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #4: Local:Peer
16:43:50 ipsec,debug dh_group = 3072-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #5: Local:Peer
16:43:50 ipsec,debug dh_group = 2048-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #6: Local:Peer
16:43:50 ipsec,debug dh_group = 1536-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #7: Local:Peer
16:43:50 ipsec,debug dh_group = 1024-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #8: Local:Peer
16:43:50 ipsec,debug dh_group = 768-bit MODP group:768-bit MODP group
16:43:50 ipsec,debug -compare proposal #9: Local:Peer
16:43:50 ipsec,debug (encklen = 192:128)
16:43:50 ipsec,debug -compare proposal #10: Local:Peer
16:43:50 ipsec,debug -compare proposal #11: Local:Peer
16:43:50 ipsec,debug -compare proposal #12: Local:Peer
16:43:50 ipsec,debug -compare proposal #13: Local:Peer
16:43:50 ipsec,debug -compare proposal #14: Local:Peer
16:43:50 ipsec,debug -compare proposal #15: Local:Peer
16:43:50 ipsec,debug -compare proposal #16: Local:Peer
16:43:50 ipsec,debug -compare proposal #17: Local:Peer
16:43:50 ipsec,debug (encklen = 128:128)
16:43:50 ipsec,debug -compare proposal #18: Local:Peer
16:43:50 ipsec,debug -compare proposal #19: Local:Peer
16:43:50 ipsec,debug -compare proposal #20: Local:Peer
16:43:50 ipsec,debug -compare proposal #21: Local:Peer
16:43:50 ipsec,debug -compare proposal #22: Local:Peer
16:43:50 ipsec,debug -compare proposal #23: Local:Peer
16:43:50 ipsec,debug -compare proposal #24: Local:Peer
16:43:50 ipsec,debug -an acceptable proposal found-
16:43:50 ipsec,debug -agreed on pre-shared key auth-
16:43:50 ipsec,debug add payload of len 96, next type 10
16:43:50 ipsec,debug add payload of len 24, next type 0
16:43:50 ipsec,debug 156 bytes from 192.77.63.18[500] to 25.2.198.15[500]
16:43:50 ipsec,debug 1 times of 156 bytes message will be sent to 25.2.198.15[500]
16:43:50 ipsec sent phase1 packet 192.77.63.18[500]<=>25.2.198.15[500] ea04183c7081318c:cda276ae7e791301
16:43:50 ipsec,debug ===== received 148 bytes from 25.2.198.15[500] to 192.77.63.18[500]
16:43:50 ipsec,debug seen nptype=4(ke) len=100
16:43:50 ipsec,debug seen nptype=10(nonce) len=20
16:43:50 ipsec,debug nonce 1:
16:43:50 ipsec,debug b4d36683 b4ade57d 021f3a52 89817b34 ab95ac7c 8872f7f5
16:43:50 ipsec,debug nonce 2:
16:43:50 ipsec,debug 0627b6a0 a5728e36 73df3668 7ca5ad35
16:43:50 ipsec,debug SKEYID computed:
16:43:50 ipsec,debug 5c16a33e 96896bde ae443df4 738a5d34 2fc63e26
16:43:50 ipsec,debug SKEYID_d computed:
16:43:50 ipsec,debug 89b3db53 8a156108 dee88ff6 0b66dddf e61c3115
16:43:50 ipsec,debug SKEYID_a computed:
16:43:50 ipsec,debug a42138b3 071dec66 5387cb52 6e01b4fb e023b543
16:43:50 ipsec,debug SKEYID_e computed:
16:43:50 ipsec,debug a2e21ef8 81ac3025 43006304 52d9914c 011e47c3
16:43:50 ipsec,debug final encryption key computed:
16:43:50 ipsec,debug IV computed:
16:43:50 ipsec,debug aa78f3b3 0668e8a7 3ebcbb53 5eee222d
16:43:50 ipsec,debug use ID type of IPv4_address
16:43:50 ipsec,debug add payload of len 8, next type 8
16:43:50 ipsec,debug add payload of len 20, next type 0
16:43:50 ipsec,debug 76 bytes from 192.77.63.18[500] to 25.2.198.15[500]
16:43:50 ipsec,debug 1 times of 76 bytes message will be sent to 25.2.198.15[500]
16:43:50 ipsec IPsec-SA expired: ESP/Tunnel 25.2.198.15[500]->192.77.63.18[500] spi=0x10d839a
16:43:50 ipsec,debug ===== received 76 bytes from 25.2.198.15[500] to 192.77.63.18[500]
Hm. In the IKE session where Mikrotik acts as initiator, it sends the Phase 2 negotiation packet multiple times and the remote peer doesn’t respond to it at all:
then 16:43:30, then 16:43:40.
At 16:43:48, an incoming attempt from the remote peer is received but it seems not to be accepted, so I guess the configuration conversion from 6.43.16 to 6.45.7 didn’t go completely well. Please show me the current /export verbose hide-sensitive.
thank you very much. Bellow is the export. Sorry for the late response
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.45.7 (c) 1999-2019 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
dec/03/2019 12:49:09 by RouterOS 6.45.7
model = RB1100Dx4
serial number = bla bla
add admin-mac=84:4D:28:D6:44:DD ageing-time=5m arp=enabled arp-timeout=auto
auto-mac=no dhcp-snooping=no disabled=no fast-forward=yes forward-delay=15s
igmp-snooping=no max-message-age=20s mtu=auto name=bridge-local priority=
0x8000 protocol-mode=rstp transmit-hold-count=6 vlan-filtering=no
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled
arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited
comment=isp1 disabled=no full-duplex=yes l2mtu=1592 loop-protect=default
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=
14:4D:28:D8:44:DC mtu=1500 name=ether1-wan orig-mac-address=
14:4D:28:D8:44:DC rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=
14:4D:28:D8:44:DD mtu=1500 name=ether2 orig-mac-address=74:3D:28:D8:44:DD
set [ find default-name=ether3 ] advertise=
74:3D:28:D8:44:DE mtu=1500 name=ether3 orig-mac-address=74:3D:28:D8:44:DE
set [ find default-name=ether4 ] advertise=
74:3D:28:D8:44:DF mtu=1500 name=ether4 orig-mac-address=74:3D:28:D8:44:DF
set [ find default-name=ether5 ] advertise=
74:3D:28:D8:44:E0 mtu=1500 name=ether5 orig-mac-address=74:3D:28:D8:44:E0
set [ find default-name=ether6 ] advertise=
74:3D:28:D8:44:E1 mtu=1500 name=ether6 orig-mac-address=74:3D:28:D8:44:E1
set [ find default-name=ether7 ] advertise=
74:3D:28:D8:44:E2 mtu=1500 name=ether7 orig-mac-address=74:3D:28:D8:44:E2
set [ find default-name=ether8 ] advertise=
74:3D:28:D8:44:E3 mtu=1500 name=ether8 orig-mac-address=74:3D:28:D8:44:E3
set [ find default-name=ether9 ] advertise=
74:3D:28:D8:44:E4 mtu=1500 name=ether9 orig-mac-address=74:3D:28:D8:44:E4
set [ find default-name=ether10 ] advertise=
74:3D:28:D8:44:E5 mtu=1500 name=ether10 orig-mac-address=74:3D:28:D8:44:E5
set [ find default-name=ether11 ] advertise=
74:3D:28:D8:44:E6 mtu=1500 name=ether11 orig-mac-address=74:3D:28:D8:44:E6
set [ find default-name=ether12 ] advertise=
74:3D:28:D8:44:E7 mtu=1500 name=ether12 orig-mac-address=74:3D:28:D8:44:E7
set [ find default-name=ether13 ] advertise=
74:3D:28:D8:44:E8 mtu=1500 name=ether13 orig-mac-address=74:3D:28:D8:44:E8
/queue interface
set bridge-local queue=no-queue
/interface ethernet switch
set 0 !cpu-flow-control mirror-source=none mirror-target=none name=switch1
set 1 !cpu-flow-control mirror-source=none mirror-target=none name=switch2
set 2 !cpu-flow-control mirror-source=none mirror-target=none name=switch3
set [ find name=all ] comment=“contains all interfaces” exclude=“” include=“”
name=all
set [ find name=none ] comment=“contains no interfaces” exclude=“” include=“”
name=none
set [ find name=dynamic ] comment=“contains dynamic interfaces” exclude=“”
include=“” name=dynamic
add comment=“WAN ports” exclude=“” include=“” name=WAN
add comment=“LAN ports” exclude=“” include=“” name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet
default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types=“” disable-pmkid=no eap-methods=
passthrough group-ciphers=aes-ccm group-key-update=5m interim-update=0s
management-protection=disabled mode=none mschapv2-username=“” name=default
radius-called-format=mac:ssid radius-eap-accounting=no
radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=
disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none
static-sta-private-algo=none static-transmit-key=key-0 supplicant-identity=
MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=
aes-ccm
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value=“0xff$(CLIENT_DUID)”
set clientid code=61 name=clientid value=“0x01$(CLIENT_MAC)”
set hostname code=12 name=hostname value=“$(HOSTNAME)”
/ip hotspot profile
set [ find default=yes ] dns-name=“” hotspot-address=0.0.0.0 html-directory=
hotspot html-directory-override=“” http-cookie-lifetime=3d http-proxy=
0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit=“” smtp-server=
0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list=“” idle-timeout=none
!insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=
default !parent-queue !queue-type shared-users=1 status-autorefresh=1m
transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=
aes-256,aes-192,aes-128,3des,des hash-algorithm=sha1 lifetime=1d name=
default nat-traversal=yes proposal-check=obey
/ip ipsec peer
add address=25.2.198.15/32 comment=Office disabled=no exchange-mode=main name=
peer1 profile=default send-initial-contact=yes
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512,sha256,sha1,md5,null disabled=
no enc-algorithms=“aes-256-cbc,aes-256-ctr,aes-256-gcm,camellia-256,aes-192-
cbc,aes-192-ctr,aes-192-gcm,camellia-192,aes-128-cbc,aes-128-ctr,aes-128-gcm
,camellia-128,3des,blowfish,twofish,des,null” lifetime=30m name=default
pfs-group=modp768
add address-pool=pool-lan authoritative=yes disabled=no interface=bridge-local
lease-script=“” lease-time=10m name=dhcp-lan use-radius=no
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
set 1 baud-rate=115200 data-bits=8 flow-control=none name=serial1 parity=none
stop-bits=1
/ppp profile
set *0 address-list=“” !bridge !bridge-horizon !bridge-path-cost
!bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout
!incoming-filter !insert-queue-before !interface-list !local-address name=
default on-down=“” on-up=“” only-one=default !outgoing-filter !parent-queue
!queue-type !rate-limit !remote-address !session-timeout use-compression=
default use-encryption=default use-mpls=default use-upnp=default
!wins-server
set *FFFFFFFE address-list=“” !bridge !bridge-horizon !bridge-path-cost
default-encryption on-down=“” on-up=“” only-one=default !outgoing-filter
!parent-queue !queue-type !rate-limit !remote-address !session-timeout
use-compression=default use-encryption=yes use-mpls=default use-upnp=
default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32
pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=
32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1-wan queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set ether6 queue=only-hardware-queue
set ether7 queue=only-hardware-queue
set ether8 queue=only-hardware-queue
set ether9 queue=only-hardware-queue
set ether10 queue=only-hardware-queue
set ether11 queue=only-hardware-queue
set ether12 queue=only-hardware-queue
set ether13 queue=only-hardware-queue
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id !confederation
disabled=no ignore-as-path-len=no name=default out-filter=“”
redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id
!domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20
!mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0 !routing-table
!use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5
encryption-protocol=DES name=public read-access=yes security=none
write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=
0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=
bsd-syslog target=remote
/user group
set read name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,web
,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude” skin=default
set write name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,pass
word,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude” skin=default
set full name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,wi
nbox,password,web,sniff,sensitive,api,romon,dude,tikapp” skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled
mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path=“”
require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=yes crl-store=ram crl-use=yes
add auto-isolate=no bpdu-guard=no bridge=bridge-local broadcast-flood=yes
disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=
yes ingress-filtering=no interface=ether2 internal-path-cost=10 learn=auto
multicast-router=temporary-query path-cost=10 point-to-point=auto priority=
0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no
unknown-multicast-flood=yes unknown-unicast-flood=yes
yes ingress-filtering=no interface=ether3 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether4 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether5 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether6 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether7 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether8 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether9 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether10 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether11 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether12 internal-path-cost=10 learn=auto
yes ingress-filtering=no interface=ether13 internal-path-cost=10 learn=auto
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no
use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes
tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-max-retrans-timeout=
5m tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s
tcp-time-wait-timeout=10s tcp-unacked-timeout=5m udp-stream-timeout=3m
udp-timeout=10s
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes arp-timeout=
30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes
max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=yes
send-redirects=yes tcp-syncookies=no
/interface detect-internet
set detect-interface-list=none internet-interface-list=none lan-interface-list=
none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 caller-id-type=
ip-address default-profile=default-encryption enabled=no keepalive-timeout=
30 max-mru=1450 max-mtu=1450 max-sessions=unlimited mrru=disabled
one-session-per-host=no use-ipsec=no
add disabled=no interface=ether2 list=LAN
add disabled=no interface=ether3 list=LAN
add disabled=no interface=ether4 list=LAN
add disabled=no interface=ether5 list=LAN
add disabled=no interface=ether6 list=LAN
add disabled=no interface=ether7 list=LAN
add disabled=no interface=ether8 list=LAN
add disabled=no interface=ether9 list=LAN
add disabled=no interface=ether10 list=LAN
add disabled=no interface=ether11 list=LAN
add disabled=no interface=ether12 list=LAN
add disabled=no interface=ether13 list=LAN
add disabled=no interface=ether1-wan list=WAN
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=no
keepalive-timeout=60 mac-address=FE:C2:6C:AB:8A:4A max-mtu=1500 mode=ip
netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=
no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 max-mtu=
1500 mrru=disabled pfs=no port=443 tls-version=any
verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses=“” caps-man-certificate-common-names=“”
caps-man-names=“” certificate=none discovery-interfaces=“” enabled=no
interfaces=“” lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.1.199/24 disabled=no interface=bridge-local network=
192.168.1.0
add address=192.77.63.18/24 disabled=no interface=ether1-wan network=192.77.63.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set accounting=yes interim-update=0s store-leases-disk=5m
add address=192.168.1.0/24 caps-manager=“” dhcp-option=“” dns-server=
192.168.1.199 gateway=192.168.1.199 ntp-server=“” wins-server=“”
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-concurrent-queries=100 max-concurrent-tcp-sessions=20
max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s
servers=8.8.8.8
/ip dns static
add address=192.168.1.199 disabled=no name=router regexp=“” ttl=1d
add address=192.168.1.0/24 disabled=no list=Internet
add action=accept chain=forward comment=“accept established,related,untracked”
Internet
add action=accept chain=srcnat !connection-bytes !connection-limit
!connection-mark !connection-rate !connection-type !content disabled=yes
!dscp dst-address=192.168.2.0/24 !dst-address-list !dst-address-type
!dst-limit !dst-port !fragment !hotspot !icmp-options !in-bridge-port
!in-bridge-port-list !in-interface !in-interface-list !ingress-priority
!ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix=“”
!nth !out-bridge-port !out-bridge-port-list !out-interface
!out-interface-list !packet-mark !packet-size !per-connection-classifier
!port !priority !protocol !psd !random !routing-mark !routing-table
src-address=192.168.1.0/24 !src-address-list !src-address-type
!src-mac-address !src-port !tcp-mss !time !tls-host !to-addresses !to-ports
!ttl
out-interface-list=WAN !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment=“counters and limits for trial users”
disabled=no name=default-trial
/ip ipsec identity
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer1
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer2
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer3
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer4
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer5
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer6
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer7
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer8
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer9
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer10
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer11
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer12
add auth-method=pre-shared-key disabled=no generate-policy=no peer=peer13
/ip ipsec policy
set 0 disabled=yes dst-address=::/0 group=default proposal=default protocol=all
src-address=::/0 template=yes
add action=encrypt comment=Office disabled=no dst-address=192.168.2.0/24
dst-port=any ipsec-protocols=esp level=require peer=peer1 proposal=default
protocol=all sa-dst-address=:: sa-src-address=:: src-address=192.168.1.0/24
src-port=any tunnel=yes
/ip ipsec settings
set accounting=yes interim-update=0s xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster
cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no
max-cache-object-size=2048KiB max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no
src-address=::
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref
!bgp-med !bgp-origin !bgp-prepend !check-gateway disabled=no distance=1
dst-address=0.0.0.0/0 gateway=192.77.63.1 !route-tag !routing-mark scope=30
target-scope=10
/ip service
set telnet address=“” disabled=no port=23
set ftp address=“” disabled=no port=21
set www address=“” disabled=no port=80
set ssh address=“” disabled=no port=22
set www-ssl address=“” certificate=none disabled=yes port=443
set api address=“” disabled=no port=8728
set winbox address=“” disabled=no port=8291
set api-ssl address=“” certificate=none disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment=“default share” directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no
host-key-size=2048 strong-crypto=no
/ip tftp settings
set max-block-size=4096
/ip traffic-flow
set active-flow-timeout=30m cache-entries=256k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes
dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes
igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes
ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=yes
nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=yes
packets=yes protocol=yes src-address=yes src-address-mask=yes
src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes tcp-seq-num=
yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no
use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-community=public
trap-generators=temp-exception trap-target=“” trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=Europe/Bucharest
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system identity
set name=MyRouter
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix=“” topics=info
set 1 action=memory disabled=no prefix=“” topics=error
set 2 action=memory disabled=no prefix=“” topics=warning
set 3 action=echo disabled=no prefix=“” topics=critical
add action=memory disabled=no prefix=“” topics=ipsec,!packet
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=“”
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
/system resource irq rps
set ether1-wan disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
set ether10 disabled=yes
set ether11 disabled=yes
set ether12 disabled=yes
set ether13 disabled=yes
/system routerboard settings
set auto-upgrade=no baud-rate=115200 boot-delay=2s boot-device=
nand-if-fail-then-ethernet boot-protocol=bootp enable-jumper-reset=yes
enter-setup-on=any-key protected-routerboot=disabled reformat-hold-button=
20s reformat-hold-button-max=10m silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes ping-start-after-boot=5m
ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number=“” auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name=“” filter-cpu=“” filter-direction=any
filter-interface=“” filter-ip-address=“” filter-ip-protocol=“”
filter-ipv6-address=“” filter-mac-address=“” filter-mac-protocol=“”
filter-operator-between-entries=or filter-port=“” filter-stream=no
memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=no
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=no
stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups=“” interim-update=0s
use-radius=no
These two things fo not match each other to me, except if Cisco uses other exchange mode than main and the log message is confusing:
vs.
/ip ipsec peer
add address=25.2.198.15/32 comment=Office disabled=no exchange-mode=main name=peer1 profile=default send-initial-contact=yes
So to obtain some additional information, I’d recommend to set passive=yes on the Mikrotik peer, so that we could see the Phase 2 proposal coming from the Cisco while it acts as an initiator, and if you keep seeing “no IKEv1 peer config for 25.2.198.15” message, try to set that peer’s exchange-mode to aggressive and base one-by-one.
The Cisco obviously did respond to our initial message, so exchange mode main is not a show stopper on its own, but as we want to see the Cisco’s phase 2 proposal, we need to accommodate to its initial request.
Hello, thank you, i didn’t changed the peer as you suggested, but it give me an idea, I changed on the Linksys (actually i disabled) Aggressive mode and now the VPN work’s.
The rest off the config is the same.
I don’t understand how come this mattered so much.
In the old config (with Cisco/Linksys) i used Aggressive mode for DEAD peer.
