I am having a problem with Mikrotik routerboard using latest OS: 2.9.46
Recently our PPTP VPN stopped working. We have discovered that we cannot ping the WAN interface of the router from the LAN. There isn’t response.
Also, what we found is that when we run a trace route to the IP of the WAN interface, it will hop through that interface and attempt to continue routing.
I do have an IPSEC tunnel that forwards through the NAT, but the Mikrotik is not handling that transaction. I don’t think that could cause the problem however, as we disabled the port/protocol forwarding for the IPSEC tunnel and it still did not resolve this issue.
U should verify rules at a.a.a.b. Next, all routers between 2 routers making vpn. Ping and traceroute between is necessary, but unfortunately not sufficient condition.
In one word, check all routers between: routing, firewall, etc. Ping and traceroute cannot disapear accidentally. Remember all changes in all routers. Also check “/ ip firewall service-port pr” pptp should be enabled.
Thanks chvdr. I think the subject of my post is misleading. We discovered the problem when the VPN stopped working, but upon investigation the problem seems to be more far-reaching and the VPN issue is a side-effect.
I cannot ping the WAN side IP address from inside the LAN at all! Even if the router were not connect to any networks on the WAN side, I should still be able to ping the address.
