VPN, RDP and Synology ports
Hello community,
Long story short, I bought some Hex S for business use, in order to connect our IP Phones and computers to our HQ and be able to accept and make phone calls. Although the IP phones are working perfectly, I can’t pass traffic through the VPN. I followed this guide https://www.watchguard.com/help/docs/help-center/en-US/Content/Integration-Guides/General/Mikrotik%20VPN_firebox.html in order to make the VPN. I have firmware 6.46.6
Both Phase 1 and 2 are working, I can ping servers in HQ, and when I try to RDP them but I get a black screen and a “Reconnecting” screen. Then the Reconnecting screen dissappear, still blackscreen, and then again the Reconnecting screen re-appear.
I want the 192.168.40.0/24 site to have full access with mine (192.168.36.0/24) and I don’t know how to do it.
Some note. As you will see from my configuration, I use PPPoE to connect, while the other Hex S just get internet from the provider Modem. But everyone has issues passing traffic.
VPN-wise, if i connect a Watchguard, everything work as they should and the speed is quite fast. Once I remove it and replace it with Mikrotik, same issues again.
Thank you for your time.
add admin-mac=C4:AD:34:D7:15:C2 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=v42049471
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
/ip ipsec peer
add address=83.235.23.9/32 exchange-mode=ike2 local-address=192.168.36.1 name=peer1
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc,aes-128-cbc pfs-group=modp2048
add name=dhcp ranges=192.168.36.10-192.168.36.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.36.1/24 comment=defconf interface=ether2 network=192.168.36.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.36.4 mac-address=0C:2F:B0:9D:DA:18 server=defconf
add address=192.168.36.3 mac-address=E8:D0:FC:EF:04:1D server=defconf
add address=192.168.36.222 mac-address=00:11:32:BE:E1:CA server=defconf
add address=192.168.36.221 mac-address=54:E4:BD:48:FC:F1 server=defconf
add address=192.168.36.0/24 comment=defconf gateway=192.168.36.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.36.1 comment=defconf name=router.lan
add action=accept chain=input comment="WinBox WAN Administration" dst-port=8291 protocol=tcp src-address=192.168.40.5
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=srcnat dst-address=192.168.40.0/24 out-interface=ether1 src-address=192.168.36.0/24
add action=dst-nat chain=dstnat dst-port=5000-5001 protocol=tcp to-addresses=192.168.36.222 to-ports=5000-5001
/ip ipsec identity
add peer=peer1
/ip ipsec policy
add dst-address=192.168.40.0/24 level=unique peer=peer1 sa-dst-address=83.235.23.9 sa-src-address=192.168.36.1 src-address=192.168.36.0/24 tunnel=yes
add dst-address=192.168.42.0/24 level=unique peer=peer1 sa-dst-address=83.235.23.9 sa-src-address=192.168.36.1 src-address=192.168.36.0/24 tunnel=yes
add dst-address=192.168.43.0/24 level=unique peer=peer1 sa-dst-address=83.235.23.9 sa-src-address=192.168.36.1 src-address=192.168.36.0/24 tunnel=yes
add dst-address=192.168.44.0/24 level=unique peer=peer1 sa-dst-address=83.235.23.9 sa-src-address=192.168.36.1 src-address=192.168.36.0/24 tunnel=yes
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=MikroTik_36
/tool mac-server
/tool mac-server mac-winbox
UPDATE: At IP → Firewall → NAT i got rid of the Out. Interface → ether1 and I see some packets, but still can’t pass traffic. So the current rule is:
add action=accept chain=srcnat dst-address=192.168.40.0/24 src-address=192.168.36.0/24
Please assist me before I go crazy.
Regards
Dear all,
My ISP supported NAT and the real external IP was not the one reporting outside.
I disabled NAT on ISP’s page and after a reboot of Mikrotik, everything is working.
Regards
