VPN routing
Hi, we have Main office and branch office,we are using inhouse management system (customize software), we want to use software from branch office to main office,and the main server is in main office, we have 4mbps CIR both side,now i need full solution that which VPN protocol will be best for secure and also for fast data connectivity or any other solution in Mikrotik…
thanks
What do you think is the best? Did you any own research? Have you already tried anything? Results? Or are you just waiting for the first answer and then you are ready to ask for a step-by-step all in one manual that will exactly fit your needs even not written above?
Fine. Try l2tp+ipsec.
