VPN scheduling.
Can a Mikrotik be programmed such that it will establish a VPN connection with another Mikrotik on a scheduled basis? So, for instance, it would connect the VPN at 8 AM and disconnect it at 5 PM. Or it might connect the VPN for 10 minutes at the start of each hour then disconnect.
Yes, you can add script that will disable/enable VPN and run that script from /system scheduler
