VPN Server Behind Double Nat (LTE)
I have LTE internet and Mikrotik router which is double or tripple nat’d because well its LTE internet.
I need to setup the mikrotik router to be a vpn server so that windows wireguard clients can connect.
What i did in one place was use a different mikrotik router that was not behind LTE internet made it the server then do a site to site wireguard connection between the 2 mikrotik routers then connect the windows clients to the mikrotik thats not LTE ISP and it works but its not a sustainable solution to roll out large scale.
So i was wondering does cloudflare or tailscale offer something that you could use them as the vpn server, connect the mikrotik to that vpn and then the windows clients can connect through cloudflare/tailscale and have access to server behind mikrotik. Same idea as what i was doing with my 2 mikrotiks.
Hopefully thats clear enough.
The answer is ZEROTIER.
