VPN Setup Brick Wall :-?
I am trying to set up the VPN server on my router all weekend, but have run into the end of what I seem to be able to make work.
My goals:
  • Give a few friends a connection to my network to browse local resources, without passing all their other traffic through my network.
  • Set up a full tunnel for my own traffic, so I can use it as a secure connection when I am out.
Here’s a drawing:
http://grab.by/Mx58
So far, I have a working PPTP connection from my (external) laptop to my network.
If I enable default gateway, I can access internal resources, if I disable it, I can access external resources.
From my digging, it seems like I need to add a route to the VPN connection that will be pushed on connect (and I would prefer to do this over setting a static route on the client).
I am not sure what to add in that box though, to make my laptop able to access internal resources without the default gateway turned on.
http://grab.by/Mx5k
What settings on the router do I need to set other than what I have below to make my goals work?
Please give me config lines or step by step instructions, if possible.
# dec/06/2015 20:03:01 by RouterOS 6.33.3
add name=InternalPool ranges=192.168.0.105-192.168.0.200
add name=PPTPPool ranges=192.168.20.100-192.168.20.200
/ppp profile
add local-address=InternalPool name=pptp-profile remote-address=PPTPPool
/interface pptp-server server
set authentication=mschap2 enabled=yes
add chain=input comment="Accept Ping" protocol=icmp
add chain=input comment="Accept Established" connection-state=established
add chain=input comment="Accept Related" connection-state=related
add chain=input comment="VPN Rule" protocol=gre
add chain=input comment="VPN Rule" dst-port=1723 protocol=tcp
add action=drop chain=input in-interface=sfp1-gateway
add action=drop chain=input in-interface=FiberOp-VLAN
add action=masquerade chain=srcnat out-interface=FiberOp-VLAN src-address=192.168.0.0/24
/ppp secret
add name=ben profile=pptp-profile
[/size]
I just src-nat using the masquerade function of the src-nat facility. I make the dst-addr the address of the VPN and also the out-interface the PPTP (VPN) interface. That seems to do the trick just fine for me.
Thom
It looks like your VPN users are being assigned IP addresses from your LAN, which is fine and makes your goal very easy.
You need to set arp=proxy-arp on the LAN interface, and don’t send default GW to your friends’ connections, but send default GW to yours.
That should do what you want.
