VPN setup for specific domains
im new to RouteOS
i have a mikrotik hAP AC Lite,
and i like to connect to it via WiFi.
the configuration i like to do is :
a VPN CLIENT to connect to some specific domains or ips that are filtered(Black Listed By ISP)
in my country there is censorship for some domains and sites I Like to connect to the Game Servers And Sites that are not filtered through the regular Internet and Use VPN Only on ips/Domains That Are filtered(Backlisted)
all the blocked sites/ips are redirected to 10.10.34.36
if i ping facebook.com i will get: Pinging facebook.com [10.10.34.36] with 32 bytes of data:
is there a way to check if this ip is the DNS of site , Use VPN to Connect to it automatically or add the domain/ip to the list that use the VPN To connect to?
is using mikrotik affect online gaming experience(with or with out this config)?
i used this tut to Enable the WiFi:(with same ip ranges and …)
https://www.youtube.com/watch?v=fIAKUWnCEEU
i tried this article to achieve this configuration but it didn’t worked:https://itectec.com/superuser/mikrotik-and-vpn-for-specific-web-sites-only/
im using PPTP for VPN
How can i do this?
Thank You
So you’re Iranian? if so contact me discord
I will help you config what you want to do but I just don’t want to type a long text and config here.
edited
edited
