VPN SITE TO SITE ON INTERNET BEHIND NATED NETWORK
Hi guys, below one lab about configuration.
Below my blog address
http://gmarciales.blogspot.com/
Regards.
Try “NAT Traversal” in IPsec Peer configuration.
Hi kburzyns, to do NAT Traversal you need to make changes in the front nated gateway, with the option I proposed you do not need touch the the front nat gateway, it was our environment when we did it.
In my opinion You don’t need to modify front_nat_network router. I have an example configuration made on Cisco devices. On Mikrotik it should be the same.
Routers configuration below.
True, you are well, my apologize, I was wrong, really thanks for your comments about, I appreciate a lot. I attached my setting based in your idea.
Otherwise, we will should do it with RouterOS…jajaja
Regards!!!
https://www.youtube.com/watch?v=ulfCVCCLiVQ
