Hi i have two MikroTik routers connected using IKEv2 VPN with certificates, the connection works, and is established, i can also ping one another’s vpn network address. Unfortunatly i have trouble to connect to the others LAN network on the opposite routers. (I need to create connection from 192.168.200.0/24 to 192.168.45.0/24)
Setup is:
Router A (Server):
VPN Peer Passive
VPN netwrok ip: 10.22.22.1
LAN netwrok 192.168.200.0/24
Routing 192.168.45.0/24 throu gateway 10.22.22.2
Router B (client):
VPN Peer not passive
VPN network ip: 10.22.22.2
LAN network: 192.168.45.0/24
Routing 192.168.20.0/24 throu gateway 10.22.22.2
I don’t think the problem is with firewall filters and raw as even with allowing all will not fix the issue, if anyone has any idea i would appreciate the help. (Also dont be weirded out by the public IPs i anonymised them) RouterClient.txt (23.2 KB) RouterServer.txt (33.1 KB)
Instead of creating a tunnel between the VPN addresses of the tunnel on client side, you could use a policy template. As for the communication between the LANs, it should be quite an easy fix:
Do you mean by that i should make this a template what you wrote ? because everytime i write it it changes its adrress, orshould it be a tunnel ? I have other VPN server running at same time, also sorry for maybe dumb questions but im still quite new to thee VPNs in mikrotik.
Unfortunatly the mikrotik for some reason is not routing it, its returning net unreachable. Should i also change the mode config ? (Tried different variants and still can’t do it, also tried again to open entire firewall if its wrong firewall conf but no)
