Good mornging from Spain. First thing is to apologize because probably this is a basic question but I’m a noob and everything I do is read and copy/paste…
I have OpenVPN working between my iPhone and my router. If I set Pool to asign the iPhone a IP in the LAN range (192.168.1.0/24) I can access both internet and my PC at home, but if I set Pool in a differente range (10.0.0.0/24 so there is no conflict if I’m in a public wifi with the same range as my LAN) I can access internet but not my PC. As far as I know, the solution is to establish a bridge between VPN and LAN but I don’t know how to do it…
Any help will be very welcome
Thank you in advance
It’s not a bridge you need, but a route on your iPhone to send 192.168.1.0/24 packets over the VPN. However this will also conflict with the local network you iPhone is connected.
Options:
- Change home IP subnet
- Set iPhone to send ALL traffic over the VPN. Then your iPhone will connect to your home devices, but not local devices (in the event there is an IP conflict).
- Use dst-nat (forwarding). Set forwarding rules in your firewall > NAT. When traffic is destined to the 10.0.0.0/24 IP of your Mikrotik, forward it to your PC. You’d also need a masquerade rule for traffic going out the VPN interface. Which means you have to configure a VPN interface for your username in the Mikrotik…
Option 1 seems easiest?
