I have 4 locations that I have RB2011’s in. My problem is that the VPN connection between the offices will not stay up for any give period of time. Here is a a breakdown of how the network is setup
jan/03/1970 04:47:54 by RouterOS 6.10 on all routers
Location 1
address=172.16.10.1 comment=LAN interface=ether2
address=1.1.1.1/30 comment=WAN interface-ether1
add chain=srcnat comment=Location 3 dst-address=172.16.12.0/24 src-address=172.16.10.0/24
add chain=srcnat comment=Location 4 dst-address=172.16.13.0/24 src-address=172.16.10.0/24
add chain=srcnat comment=Location 2 dst-address=172.16.11.0/24 src-address=172.16.10.0/24
add action=dst-nat chain=dstnat disabled=yes dst-address=0.0.0.0/0 dst-port=443 protocol=tcp to-addresses=\
172.16.10.2 to-ports=443
add action=dst-nat chain=dstnat dst-address=0.0.0.0/0 dst-port=1723 protocol=tcp to-addresses=172.16.10.2 \
to-ports=1723
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.1-xxx.xxx.xxx.254 dst-port=8889 protocol=tcp \
to-addresses=172.16.10.2 to-ports=8889
add action=dst-nat chain=dstnat dst-address=76.xxx.xxx.xxx dst-port=8889 protocol=tcp to-addresses=172.16.10.2 \
to-ports=8889
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.1-xxx.xxx.0.254 dst-port=389 protocol=tcp \
to-addresses=172.16.10.2 to-ports=389
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.1-xxx.xxx.xxx.254 dst-port=389 protocol=tcp to-addresses=\
add action=dst-nat chain=dstnat dst-address=1.1.1.1 to-addresses=172.16.10.2
add action=src-nat chain=srcnat src-address=172.16.10.2 to-addresses=1.1.1.1
add action=masquerade chain=srcnat dst-address=0.0.0.0/0 src-address=172.16.10.0/24
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=des
/ip ipsec peer
add address=4.4.4.4/30 comment=Location 4 dpd-interval=disable-dpd enc-algorithm=des \
hash-algorithm=md5 secret=test
add address=3.3.3.3/30 comment=Location 3 dpd-interval=disable-dpd enc-algorithm=des hash-algorithm=\
md5 secret=test
add address=2.2.2.2/30 comment=Location 2 dpd-interval=disable-dpd enc-algorithm=des hash-algorithm=md5 \
secret=test
/ip ipsec policy
add comment=Location 4 dst-address=172.16.15.0/24 sa-dst-address=4.4.4.4 sa-src-address=\
1.1.1.1 src-address=172.16.10.0/24 tunnel=yes
add comment=Location 3 dst-address=172.16.25.0/24 sa-dst-address=3.3.3.3 sa-src-address=\
add comment=Location 2 dst-address=172.16.11.0/24 sa-dst-address=2.2.2.2 sa-src-address=1.1.1.1 \
Location 2
address=172.16.11.1 comment=LAN interface=ether2
address=2.2.2.2/30 comment=WAN interface-ether1
add chain=srcnat comment=Location 1 dst-address=172.16.10.0/24 src-address=172.16.11.0/24
add action=masquerade chain=srcnat dst-address=0.0.0.0/0 out-interface=ether1-gateway src-address=\
172.16.11.0/24
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=des lifetime=1d pfs-group=modp768
/ip ipsec peer
add address=1.1.1.1/30 comment=Location 1 dpd-interval=disable-dpd enc-algorithm=des hash-algorithm=md5
test
/ip ipsec policy
add comment=Location 1 dst-address=172.16.10.0/24 sa-dst-address=1.1.1.1 sa-src-address=2.2.2.2 \
src-address=172.16.11.0/24 tunnel=yes
Location 3
address=172.16.25.1 comment=LAN interface=ether2
address=3.3.3.3/30 comment=WAN interface=ether1
address-3.3.3.4/30 comment=PBX interface=ether3
/ip firewall address-list
add address=172.16.25.10 list=PBX
add action=drop chain=input src-address=xxx.xxx.xxx.228
add action=drop chain=input src-address=xxx.xxx.xxx.49
add chain=srcnat comment=Location 1 dst-address=172.16.10.0/24 src-address=172.16.25.0/24
172.16.25.0/24
/ip ipsec proposal
/ip ipsec peer
add address=1.1.1.1/30 comment=Location 1 dpd-interval=disable-dpd enc-algorithm=des \
/ip ipsec policy
add comment=Vincennes dst-address=172.16.10.0/24 sa-dst-address=1.1.1.1 sa-src-address=\
3.3.3.3 src-address=172.16.25.0/24 tunnel=yes
Location 4
address=172.16.15.1 comment=LAN interface=ether2
address=4.4.4.4/30 comment=WAN interface-ether1
add chain=srcnat comment=Vincennes dst-address=172.16.10.0/24 src-address=\
172.16.15.0/24
add action=masquerade chain=srcnat dst-address=0.0.0.0/0 out-interface=\
ether1-gateway src-address=172.16.15.0/24
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=des pfs-group=modp768
/ip ipsec peer
add address=1.1.1.1/30 comment=Location 1 dpd-interval=disable-dpd enc-algorithm=des hash-algorithm=md5 secret=\
test
/ip ipsec policy
add comment=Location 1 dst-address=172.16.10.0/24 sa-dst-address=1.1.1.1 sa-src-address=4.4.4.4 src-address=\
172.16.15.0/24 tunnel=yes
I also just noticed that on on Location 1 I see this message in the terminal
[quote]
ipsec,warning,critical failed to begin ipsec sa negotiation.[code]
