vpn to netflix on ps3/ipad
so, what is the simplest way to have my mikrotik connect to VPN, but use normal ISP except when my PS3 or iPad want to open Netflix or ESPN apps which require USA IP?
thanks :slight_smile:
You can create a static route to the VPN from the PS3 IP (fixed IP) to the VPN, and the rest.. outside that route, I am doing something like that
thanks, and since im fairly new here, can you point me in the right direction of how to do that? also what VPN provider is good, reliable?
also, would this smartDNS work, but i would have to block google and public dns server as described here:
http://help.unotelly.com/support/articles/96831-how-to-block-netflix-app-on-ps3-from-using-public-dns-lookups-requires-supported-router-
is vpn better option?
