I have the following problem which I cannot figure out how to do it.
I have the next situation:
What do I want with this.
The other side is from a family member and we want to have remote acces to a NAS. We wanted to do this via VPN to not expose to many ports to the internet, also connecting to " lan" addresses is making it easier.
On my side I have the RB2011UiAS-2HnD-IN set up as router.
My router makes a PPTP VPN connection to an other location (family’s house) where a VPN server is running on a Synology DiskStation.
Unfortunately this server cannot set-up routes or push them as I understood.
So far I have it working that the VPN connection works.
From the Mikrotik (terminal) I can Ping the complete internal network on the remote side. (192.168.0.0/24 network)
[admin@HomeNetRouter] > ping 192.168.0.1
HOST SIZE TTL TIME STATUS
192.168.0.1 56 63 45ms
192.168.0.1 56 63 31ms
sent=3 received=3 packet-loss=0% min-rtt=31ms avg-rtt=35ms max-rtt=45ms
The thing I can’t get to work is acces the remote side via my internal network (192.168.88.0/24)
I have the feeling something goes wrong in the firewall, as soon as I ping from my computer the address 192.168.0.1 I can see this in the log:
Forward: in:bridge-local out:pptp-out1, src-mac 90:27:e4:fd:XX:XX, porto ICMP (type8, code 0), 192.168.88.201->192.168.0.1, len 84.
But further I do not get any reply.
I have setup the following things:
[admin@HomeNetRouter] > /interface pptp-client print
0 R name="pptp-out1" max-mtu=1450 max-mru=1450 mrru=1600
connect-to=94.208.161.XXX user="VPN Account" password="XXXXX"
profile=default-encryption keepalive-timeout=60 add-default-route=no
dial-on-demand=no allow=pap,chap,mschap1,mschap2
[admin@HomeNetRouter] /ip> address print
# ADDRESS NETWORK INTERFACE
0 ;;; default configuration
192.168.88.1/24 192.168.88.0 bridge-local
1 192.168.10.1/24 192.168.10.0 _HomeNetGuest_
2 X 192.168.11.1/24 192.168.11.0 _HomeNetHotspot_
3 D 94.208.166.XX/23 94.208.166.0 Gateway-ETH10
4 D 10.10.10.1/32 10.10.10.0 pptp-out1
[admin@HomeNetRouter] > /ip route print detail
0 ADS dst-address=0.0.0.0/0 gateway=94.208.166.1
gateway-status=94.208.166.1 reachable via Gateway-ETH10 distance=1
scope=30 target-scope=10 vrf-interface=Gateway-ETH10
1 A S dst-address=10.10.10.0/24 gateway=bridge-local
gateway-status=bridge-local reachable distance=1 scope=30
target-scope=10
2 ADC dst-address=10.10.10.0/32 pref-src=10.10.10.1 gateway=pptp-out1
gateway-status=pptp-out1 reachable distance=0 scope=10
3 ADC dst-address=94.208.166.0/23 pref-src=94.208.166.56
gateway=Gateway-ETH10 gateway-status=Gateway-ETH10 reachable
distance=0 scope=10
4 A S ;;; VPN Moeders
dst-address=192.168.0.0/24 gateway=10.10.10.0
gateway-status=10.10.10.0 reachable via pptp-out1 distance=1
5 DC dst-address=192.168.10.0/24 pref-src=192.168.10.1
gateway=_HomeNetGuest_ gateway-status=_HomeNetGuest_ unreachable
distance=255 scope=10
6 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=bridge-local
gateway-status=bridge-local reachable distance=0 scope=10
[admin@HomeNetRouter] /ip> firewall filter print
0 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough log=no log-prefix=""
1 ;;; Block Guest to Lan
chain=input action=drop src-address-list=Guest dst-address-list=Home
2 ;;; default configuration
chain=input action=accept protocol=icmp log=no log-prefix=""
3 ;;; default configuration
chain=input action=accept connection-state=established log=no
log-prefix=""
4 ;;; default configuration
chain=input action=accept connection-state=related log=no log-prefix=""
5 ;;; VPN
chain=input action=accept protocol=udp in-interface=Gateway-ETH10
dst-port=500 log=no log-prefix=""
6 chain=input action=accept protocol=udp in-interface=Gateway-ETH10
dst-port=1701 log=no log-prefix=""
7 chain=input action=accept protocol=udp in-interface=Gateway-ETH10
dst-port=4500 log=no log-prefix=""
8 chain=input action=accept protocol=ipsec-esp in-interface=Gateway-ETH10
9 ;;; VPN Moeders
chain=forward action=accept src-address=192.168.88.0/24
dst-address=192.168.0.0/24 log=yes log-prefix=""
10 chain=forward action=accept src-address=192.168.88.0/24
dst-address=10.10.10.0/24 log=yes log-prefix=""
11 chain=forward action=accept src-address=192.168.0.0/24
dst-address=192.168.88.0/24 log=yes log-prefix=""
12 chain=forward action=accept src-address=10.10.10.0/24
13 ;;; VPN Ubuntu test
chain=input action=accept protocol=tcp dst-address=192.168.88.147
in-interface=Gateway-ETH10 src-port=1723 dst-port=1723 log=no
log-prefix=""
14 ;;; NAS
chain=input action=accept protocol=tcp dst-address=192.168.88.220
in-interface=Gateway-ETH10 src-port=443 dst-port=5001 log=no
log-prefix=""
15 ;;; default configuration
chain=input action=drop in-interface=Fiber1-gateway log=no
log-prefix=""
16 ;;; default configuration
chain=input action=drop in-interface=Gateway-ETH10 log=no log-prefix=""
[admin@HomeNetRouter] > /ip firewall nat print
0 ;;; Test voor VPN Moeders
chain=srcnat action=accept src-address=192.168.88.0/24
dst-address=192.168.0.0/24 log=no log-prefix=""
1 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough to-addresses=0.0.0.0 log=no
log-prefix=""
2 X ;;; default configuration
chain=srcnat action=masquerade out-interface=Fiber1-gateway log=no
log-prefix=""
chain=srcnat action=masquerade out-interface=Gateway-ETH10 log=no
log-prefix=""
4 chain=srcnat action=masquerade src-address=192.168.10.0/24
out-interface=Gateway-ETH10 log=no log-prefix=""
Does some one have a idea what I am missing in this story?
