VPN to Router
Hello, i have proplems with my VPN
I be albe to connect via VPN but i cant reach other HOST in network, only the Router is reacheable
maby someone can help me to finde the failur or set the right rule
best regards
# jun/29/2020 18:31:14 by RouterOS 6.45.7
# software id = 0YVW-DUP3
# model = RouterBOARD wAP R-2nD
# serial number = 86C409549322
add comment="Externe Gast User" name=bridge-extern
add admin-mac=B8:69:F4:11:79:2C auto-mac=no comment="Interne Verteilung" \
    name=bridge-intern
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=drei.at authentication=pap default-route-distance=1 name=Planet3
add apn=webaut default-route-distance=1 name="HoT Internet"
/interface lte
set [ find ] apn-profiles=Planet3 mac-address=AC:FF:FF:00:00:00 name=lte1
add authentication-types=wpa2-psk eap-methods="" management-protection=\
    allowed mode=dynamic-keys name=porfile-intern supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    comment=2,4GHz disconnect-timeout=5s frequency=auto mode=ap-bridge \
    multicast-buffering=disabled multicast-helper=disabled name=wlan \
    radio-name="LTE Router" security-profile=porfile-intern ssid=LKintern1 \
    tx-power=19 tx-power-mode=all-rates-fixed wmm-support=required wps-mode=\
    disabled
add default-ap-tx-limit=56000 default-client-tx-limit=56000 keepalive-frames=\
    disabled mac-address=BA:69:F4:11:79:2D master-interface=wlan \
    multicast-buffering=disabled multicast-helper=disabled name=wlan-Gast \
    ssid="Loskrochn Gast" wds-cost-range=0 wds-default-cost=0 wps-mode=\
    disabled
add keepalive-frames=disabled mac-address=BA:69:F4:11:79:2E master-interface=\
    wlan multicast-buffering=disabled name=wlan-intern security-profile=\
    porfile-intern ssid="LKintern test" wds-cost-range=0 wds-default-cost=0 \
    wps-mode=disabled
/interface wireless nstreme
set wlan comment=2,4GHz
/interface wireless manual-tx-power-table
/ip hotspot profile
add name=pool-intern ranges=192.168.0.1-192.168.3.254
add name=pool-extern ranges=192.169.0.1-192.169.2.250
add name=pool_PPTP ranges=192.168.3.241-192.168.3.250
add address-pool=pool-extern disabled=no interface=bridge-extern name=\
    dhcp-extern
add address-pool=pool-intern disabled=no interface=bridge-intern name=\
    dhcp-intern
/ppp profile
add bridge=bridge-intern change-tcp-mss=yes dns-server=192.168.0.1 \
    local-address=192.168.0.1 name=PPTP remote-address=pool-intern \
    use-encryption=yes
set *FFFFFFFE dns-server=192.168.0.1 local-address=192.168.0.1 \
    remote-address=192.168.0.100
/system logging action
set 3 remote=192.168.0.199
add bridge=bridge-intern comment=defconf interface=ether1
add bridge=bridge-intern comment=defconf interface=wlan
add bridge=bridge-extern interface=wlan-Gast
add bridge=bridge-intern disabled=yes interface=wlan-intern
add bridge=bridge-intern disabled=yes interface=WAN
/interface detect-internet
set detect-interface-list=all
add interface=lte1 list=WAN
add interface=ether1 list=LAN
add interface=bridge-extern list=LAN
add interface=bridge-intern list=LAN
add interface=wlan-Gast list=LAN
add interface=wlan list=LAN
/interface pptp-server server
set default-profile=PPTP enabled=yes
add address=192.168.88.1/24 comment=defconf disabled=yes interface=\
    bridge-intern network=192.168.88.0
add address=192.168.0.1/16 interface=bridge-intern network=192.168.0.0
add address=192.169.0.1/16 interface=bridge-extern network=192.169.0.0
add address=192.168.0.1/16 disabled=yes interface=ether1 network=192.168.0.0
add address=192.168.10.1/16 disabled=yes interface=wlan-Gast network=\
    192.168.0.0
add address=192.168.0.1/16 disabled=yes interface=wlan network=192.168.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-server lease
add address=192.168.0.95 comment=Kasse mac-address=50:9A:4C:3C:0C:65 server=\
    dhcp-intern
add address=192.168.0.90 comment="EC " mac-address=54:7F:54:C8:28:92 server=\
    dhcp-intern
add address=192.168.3.200 client-id=1:0:f:0:53:34:56 comment=Terminal1 \
    mac-address=00:0F:00:53:34:56 server=dhcp-intern
add address=192.168.2.201 client-id=1:0:f:0:4f:ce:e9 comment="Terminal 2" \
    mac-address=00:0F:00:4F:CE:E9 server=dhcp-intern
add address=192.168.0.3 client-id=1:24:18:1d:d9:d:a2 mac-address=\
    24:18:1D:D9:0D:A2
add address=192.168.0.100 client-id=1:40:9f:38:45:42:85 comment=Lasertag \
    mac-address=40:9F:38:45:42:85 server=dhcp-intern
add address=192.168.0.150 comment=CAM mac-address=00:11:14:15:55:D9
add address=192.168.0.180 client-id=1:b8:27:eb:fd:2f:86 comment=\
    Haftungsausschluss mac-address=B8:27:EB:FD:2F:86 server=dhcp-intern
add address=192.168.0.4 client-id=1:24:18:1d:5f:3e:e mac-address=\
    24:18:1D:5F:3E:0E server=dhcp-intern
add address=192.168.0.102 client-id=1:b8:27:eb:b6:6e:3e comment=\
    "Raspy Lasertag Monitor" mac-address=B8:27:EB:B6:6E:3E server=dhcp-intern
add address=192.168.0.199 client-id=1:b8:27:eb:fa:4f:ab comment=Syslog \
    mac-address=B8:27:EB:FA:4F:AB server=dhcp-intern
add address=192.168.0.181 client-id=1:b8:27:eb:8d:c9:82 mac-address=\
    B8:27:EB:8D:C9:82 server=dhcp-intern use-src-mac=yes
add address=192.168.0.0/16 dns-server=192.168.0.1,8.8.8.8,8.8.4.4 gateway=\
    192.168.0.1 netmask=16
add address=192.169.0.0/16 dns-server=192.169.0.1,8.8.8.8,8.8.4.4 gateway=\
    192.169.0.1 netmask=16
set allow-remote-requests=yes cache-max-ttl=2d servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 comment=defconf disabled=yes name=router.lan
/ip firewall address-list
add address=192.168.0.200-192.168.3.250 list="Block Internet"
add address=192.168.10.1-192.168.15.250 list="Block Local"
add action=accept chain=forward disabled=yes dst-address=192.168.0.150 \
    dst-port=8080 log-prefix=alex protocol=tcp
    dst-port=8080 protocol=udp
    established,related,untracked log=yes log-prefix=Internet
add action=accept chain=input comment="DNS GAST" dst-port=53 in-interface=\
    bridge-extern log=yes log-prefix="DNS Gast" protocol=udp src-address=\
    192.169.0.0/16
add action=log chain=input disabled=yes
    invalid log=yes
add action=accept chain=input comment="defconf: accept ICMP" log-prefix=icmp \
    protocol=icmp
    disabled=yes in-interface-list=!LAN log=yes
add action=reject chain=forward comment="Block Local" in-interface=\
    bridge-extern log=yes log-prefix=block out-interface=bridge-intern \
    reject-with=icmp-network-unreachable src-address-list="Block Local"
add action=reject chain=forward comment="Block Internet" log-prefix=\
    "Block Internet" reject-with=icmp-network-unreachable src-address-list=\
    "Block Internet"
add action=accept chain=forward comment="Internet f\FCr GAST" dst-address=\
    !192.168.0.0/16 dst-port=80,443 in-interface=bridge-extern ipsec-policy=\
    in,ipsec log=yes log-prefix="Gast Internet" out-interface-list=WAN \
    protocol=tcp
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=established,related log-prefix=rolle12
    established,related,untracked log-prefix=rolle13
    connection-state=invalid
/ip firewall mangle
add action=change-ttl chain=postrouting comment=\
    "Maske f\EF\BF\BDr Subnetze zu Drei" disabled=yes new-ttl=set:65 \
    out-interface=lte1 passthrough=yes
add action=dst-nat chain=dstnat dst-port=8080 in-interface=lte1 log-prefix=\
    alex2 protocol=tcp to-addresses=192.168.0.150 to-ports=8080
    alex3 protocol=udp to-addresses=192.168.0.150 to-ports=8080
/ppp secret
add disabled=yes name=michi profile=PPTP service=pptp
add name=gaigg.alexander profile=PPTP service=pptp
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=LoskrochnLTE
/system logging
add action=disk disabled=yes prefix=LTE topics=lte
add action=remote topics=firewall
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system scheduler
add disabled=yes interval=1d name=Restart on-event="/system reboot" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=nov/16/2019 start-time=02:00:00
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set allowed-number="" port=lte1 receive-enabled=yes
Could you add a Network Diagram on your post ? It would help…
Hello
I want to connect via VPN over Internet to my 2nd Network
Connection work fine, but i can’t reach the other PCs
best regards
You’ve still left some space for guessing - there are two routers but just a single configuration export, so I suppose the VPN client runs directly on the topomost PC and it’s the bottom router that acts as a VPN server, i.e. that for the upper router, the VPN traffic is like any other one, is that correct?
Assuming the above, you use the same address pool to assign IP addresses to the PCs at the bottom site and to assign IP addresses to the PPTP client(s). But this means that the PCs think that the PPTP client is in their own subnet, and send ARP requests about its IP in order to be able to send them directly to the device, rather than sending the packets for that destination IP to the router for delivery. So the easiest way to fix this is /interface bridge set bridge-intern arp=proxy-arp, or to use a different pool (outside 192.168.0.0/16) for the PPTP clients.
Other than that, 192.169.0.0/16 is not a private range of IP addresses, these are normal public IPs, so your PCs may be unable to reach some sites due to this. But that’s unrelated to the subject of this topic.
By disabling the last action=drop rule in chain input of /ip firewall filter, you’ve made the router accessible from the whole internet via WAN. Since the machine acts as a VPN server, its WAN IP must be a public one, hence it is quite a serious security hole.
Is the address assigned to your VPN Client through the VPN in the same address space as the computer you want to reach ?
If not, you will need to add a peristent route on your Computer.
Hello and thx for replay
  1. Yes 2nd Router is VPN Server and Client on topomost PC
  2. With the proxy-arp it works fine :slight_smile:
  3. 192.168.0.0/16 also problems or only 192.169.0.0?
  4. you mean this rule? add action=drop chain=input comment=“defconf: drop all not coming from LAN”
best regards
192.168.0.0/16 is a private address range, like 172.16.0.0/12 and 10.0.0.0/8. Anything else is a public address, a special purpose address, or a reserved address.
Yes. The default behaviour of firewall chains in Mikrotik is “accept” - whatever doesn’t match any rule is permitted to go through at that table.
ok Thank you i have activate this rule now.
Do you have any other tips for the firewall?
  1. With the proxy-arp it works fine > :slight_smile:
That is why proxy-arp exists… So if it works where is the problem ?
https://wiki.mikrotik.com/wiki/Manual:IP/ARP#Proxy_ARP
Hello again,
today i can’t connect over VPN i think the firewallrule
block my access?
maby !LAN is the problem?
Best regards
Well, in general tampering with things before learning how they actually work is a problem.
You’ve probably disabled that rule some time in the past because the VPN did not work (maybe following some Youtube video created by someone so excited about achieving something that he had to share with the world?), therefore opening access from WAN to every service on the router, instead of adding a rule before (above) the “drop whatever didn’t come in via LAN” one that would selectively permit only PPTP access from WAN.
So the first thing is to add an chain=input protocol=tcp dst-port=1723 in-interface-list=WAN action=accept rule to the firewall, and move it before (above) the “drop whatever didn’t come in via LAN” one. This will allow the VPN client to connect again without need to keep all the doors open for everyone.
Then, edit your /ppp profile named PPTP: remove the bridge value, as it is useless if the client does not support BCP (L2 tunneling), which is definitely not the case of the Windows embedded VPN client, and set interface-list to LAN instead. This will make sure that the interface representing the local end of the tunnel to the client will be treated as a LAN one, as it will be added to the interface list LAN once it gets created when the client logs in.
Further thoughts:
  • at the moment, you may not be the only administrator of your router any more - during the period when the WAN access was fully open, some malware may have squatted in. Sophisticaded malware may leave no visible traces in the configuration. So the right thing to do would be to export (not backup) the configuration into a file, download that file to a PC, netinstall the router with the same RouterOS version (netinstall wipes the flashdisk of the router completely, so no malware can survive, which is not the case for a normal upgrade process), and import the configuration saved at the PC.
  • if you use L2TP/IPsec instead of PPTP, the configuration becomes a tiny bit more complex (you have to add different firewall rules, and you have to configure the pre-shared key at both the client PC and the router), but security is much better.
