Hello, I have an ipsec tunnel on the left side of the mikrotik on the right, I don’t know.
Mikrotik<====> some router
10.0.5.0/24 <===> 192.168.2.0/24
I need to set up an additional network on the left side but cannot access config the network on the right side.
From both subnets from left side I must access the right side
10.0.5.0./24
<===>192.168.2.0/24
192.168.4.0/24
how can i hide an extra subnet 192.168.4.0/24 to access 192.168.2.0/24
If you cannot change the setup of the right side, and it doesn’t accept additional traffic selectors proposed by the peer at the left, your only chance is to src-nat the traffic from 192.168.4.0/24 to some address(es) from 10.0.5.0/24, as below:
I think it would be good to mention that they would need to change the src-address in the policy if set as the src-nat rule will change the source address before it can hit the IPsec process as it is in the post routing section: https://wiki.mikrotik.com/wiki/File:Routing_Diagram.jpg
That’s the very essence of my suggestion - as the only available policy matches on 10.0.5.0/24 at the Mikrotik side, you have to src-nat the traffic from 192.168.4.0/24 to make it match the policy.
