Hello , i have a solution for you called statix with which can provide a static ip address for you even on the gsm 3G network, it an ip address that doesn’t depend on any isp. I can let you try and confirm. Contact me at dkgblonya@gmail.com or on skype “dangucci”
You break ISP monopoly?
The user later simply have your monopoly…
“i have built this technology on mikrotik”
you has just simply configured a mikrotik device, you do not create any new “technology”…
Anyone in the world with simply two mikrotik devices can share or rent one fixed IP with simple mikrotik setup (and intercepting any type of traffic), and can be used over any type of internet connection, and with any type of network device…
I’m not using the type of setup you stated above, This is a different one i trust you have no idea of. I would want you to try it out and testify and tell the world of it . Thanks .. Contact me dkgblonya@gmail.com or skype at “dangucci”
