Hi there,
I’m trying to configure a VPN solution using CHR, I can’t use a regular procedure to create Point-to-Point because IPs publics are not available using the ISP providers where I live.
I put a CHR in a cloud with Public IP using PPTP, server and a couple of VPN clients with Android. I can do ping between these two devices but when I added a MKT hAP2 as a third VPN client nobody can’t see the MKT and the MKT can’t see the devices, I don’t understand if I need routing or I should enable some rule in the firewalls or I’m using VPN server inappropriate. I attached the idea design.
Please help..!!
